FPGA with least power consumption
Kindly suggest a FPGA or CPLD (Preferable part with vivado support) which can have maximum 200mW power consumption. What will be the maximum power consumption for XC7A12T-1CPG238I and XC7A12T-1LCPG238I. Is -1L speed grade part recommended for latest designs.
@bivin
Will there be significant reduction in power between Spartan-7 and Artix-7. Also parts in XPE with speed grades like -2LE are not seen in vendor sites. Are these low power parts not recommended for latest designs?
The fabric is the same for Artix-7 and Spartan-7 however the logic resources are lower in Spartan-7 and so your static power will be lower in Spartan-7. Also Spartan-7 has a smaller footprint. Regarding -2LE parts, you may want to check with your distributor FAE or Xilinx FAE if you have one. Also, -2LE is only available for Artix-7 which is an overkill for your application I believe.
Is CPLD recommended for latest designs, please suggest a CPLD part with least power possible.
Personally I would not if your design is going to be a long term product. Also tool support is something you need to look at. Vivado doesn't support CPLD's. Take a look at Spartan-7 family and the lowest part XC76S may do it for you.
Which Xilinx FPGA (supported either in Vivado or ISE) consume lowest active power? What is the minimum power consumed in active state?
Depends on the part as static power is dependent on the device. Check if the XC76S fits your need and use XPE to see what you get.
Does any Xilinx FPGA/CPLD have inbuilt flash?
No in the newer 7-series family. Spartan-3AN has. Check datasheet: https://www.xilinx.com/support/documentation/data_sheets/ds557.pdf
- Giri
@bivin There is no support for CPLD in Vivado. Not sure of your requirements, but based on your description I would recommend you check out Spartan-7 over Artix-7 if you don't need Transceivers which I suspect is the case in your design. Check this white paper  https://www.xilinx.com/support/documentation/white_papers/wp488-spartan7-power.pdf
7- series Overview: http://www.xilinx.com/support/documentation/data_sheets/ds180_7Series_Overview.pdf
Regarding Power consumption, it depends on your usage and you will need to use XPE or Vivado Power to estimate based on your design. I would recommend you go through below link to get a better understanding
XPE:  https://www.xilinx.com/products/technology/power/xpe.html
           http://www.xilinx.com/video/hardware/using-the-xilinx-power-estimator.html
          http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug440-xilinx-power-estimator.pdf
Vivado Power: http://www.xilinx.com/video/hardware/power-estimation-analysis-using-vivado.html
                         http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug907-vivado-power-analysis-optimization.pdf
                         http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug997-vivado-power-analysis-optimization-tutorial.pdf
- Giri
@gnarahar
I estimated power using XPE for smallest Spartan-7 and Artix-7 but couldn't find much difference between them. Will there be significant reduction in power between Spartan-7 and Artix-7. Also parts in XPE with speed grades like -2LE are not seen in vendor sites. Are these low power parts not recommended for latest designs?
In my case, FPGA is used to generate synchronization/control waveforms, atmost 10 signals.
@bivin
- Giri
Please share XPE for Xilinx CPLD.
Is there any documents for comparison between Spartan 7 and Cool-Runner II.
@bivin
For CPLD, XPA (XPower Analyzer) should be used. There is no XPE. Check this XAPP:  https://www.xilinx.com/support/documentation/application_notes/xapp317.pdf
Also do check out the Datasheet which has more links to the various documentation.  https://www.xilinx.com/support/documentation/data_sheets/ds090.pdf
No. You are asking for a comparison between devices that are apart by almost 10 yrs :)
- Giri
@bivin as @gnarahar mentioned these devices are very different and built on very different geometries. If a CPLD can do what you are looking for then that would be by far the lowest power possible. But you need to decide on what resources you need, there is a big different between the largest CoolRunner -II CPLD and the smallest Spartan-7...
