rkfournier
Floating LVDS_25 Inputs on Artix-7
I have a couple questions on the LVDS_25 inputs on an Artix-7 device:
1). Our system design may depopulate some of the devices that are driving LVDS_25 inputs. This will leave the inputs powered and enabled with an internal termination, but with nothing driving these inputs. Will this cause any damage to the device? If yes, what should we do to protect against this situation?
2) In another part of the same system, the FPGA design uses the IBUFDS_IBUFDISABLE primitive and disables the input buffer when it detects that the driver is not present. Is this acceptable or can this also damage the device?
rkfournier
L.E.O. Thank you for your reply.
I also consulted with my local FAE and he found the following answer record:
https://www.xilinx.com/support/answers/11510.html
lowearthorbit
Damage is the result of exceeding the abs max specifications,
Nothing you have described does that.
l.e.o.
rkfournier
