08-03-2015 04:01 PM
I am switching from using a working GTX transceiver setup using the RX elastic buffer to a new setup that bypasses the elastic buffer (my design does not meet latency requirements with the elastic buffer enabled). I am using the Transceiver Wizard for setup, just like I did earlier to get the design with the elastic buffer working.
The problem I am having is that when I un-check "Enable RX Buffer" in the wizard, the resulting design shares RXUSRCLK among all of the transceivers in the quad, which I do not want, as each lane is independent.
I am doing a "from scratch" design in the wizard, and the only difference between the design with the buffer and the design bypassing the buffer un-checking "Enable RX Buffer".
In the resulting funcsim.v code I see that all RXUSRCLKs are assigned to GT0_RXUSRCLK_OUT:
assign gt0_rxusrclk2_out = gt0_rxusrclk_out;
assign gt0_txusrclk2_out = gt0_txusrclk_out;
assign gt1_rxusrclk2_out = gt0_rxusrclk_out;
assign gt1_rxusrclk_out = gt0_rxusrclk_out;
assign gt1_txusrclk2_out = gt0_txusrclk_out;
assign gt1_txusrclk_out = gt0_txusrclk_out;
assign gt2_rxusrclk2_out = gt0_rxusrclk_out;
assign gt2_rxusrclk_out = gt0_rxusrclk_out;
assign gt2_txusrclk2_out = gt0_txusrclk_out;
assign gt2_txusrclk_out = gt0_txusrclk_out;
assign gt3_rxusrclk2_out = gt0_rxusrclk_out;
assign gt3_rxusrclk_out = gt0_rxusrclk_out;
assign gt3_txusrclk2_out = gt0_txusrclk_out;
assign gt3_txusrclk_out = gt0_txusrclk_out;
Am I misunderstanding how the GTX quad works when the buffer is bypassed? I know that RXOUTCLK is set to RXOUTCLKPMA, which stands to reason that each transceiver should be able to have its own RXUSRCLK.
I have searched these forums but have not been able to find an answer to this, so thank you for any help!
08-03-2015 10:06 PM
08-03-2015 07:34 PM
See the section "Using RX Buffer Bypass in Multi-Lane Manual Mode (GTX and GTH Transceivers)" in the following user guide: http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf (page no. 252)
Vinay
08-03-2015 07:46 PM
08-03-2015 10:06 PM
08-03-2015 10:39 PM
08-04-2015 11:35 AM
Just to make sure that I am clear on the process here, this is what I think I have to do:
1. use the wizard four times to generate four separate cores, one for each lane, all in the same quad
2. ignore the top-level of the generated cores (since they all need to be in the same quad)
3. ignore the *support.v level of the generated cores
4. build my own quad top-level with instantiations for each lane, plus usrclk_source, reset, and common instantiations
5. build a new constraints file, since the .xci and .dcp files will no longer be useful
6. synthesize the IP (I am doing batch synthesis)
7. synthesize the rest of the design
Is this right, or is there a better methodology?
08-07-2015 02:18 PM
For anyone else that may be trying to do something similar, I would not recommend my procedure above.
Instead, generate one quad with four transceivers and one quad with a single transceiver, with both setup to bypass the RX/TX buffers.
Then modify the *_gt_usrclk_source.v file of the 4-lane quad to get independent RX/TX clocks.
Next, in *_init.v file of the 4-lane quad, replace the instantiations (and associated assigns) for the RX and TX manual phase align FSMs (*_manual_phase_align.v) with instantiations (and associated assigns) for the auto phase align FSMs from the *_init.v file of the 1-lane quad (*_auto_phase_align.v). Since the 4-lane design shares some outputs from the phase alignment FSMs with all lanes, you will need to search/replace these signals to make sure all 4 lanes are independent.
Remove the *manual_phase_align.v files from the 4-lane quad example folder and replace with the *auto_phase_align.v file from the 1-lane quad example folder.
Finally, open the *_multi_gt.v file for the 4-lane quad and change the PCS_RSVD_ATTR_IN to clear bits 1 and 2, as per UG476 single-lane buffer bypass instructions.
While the .dcp is no longer useful after these changes, the .xci constraints will still work in your synthesis.
If you want a new funcsim Verilog model, you will need to write it out from Vivado after synthesis.
I can provide more detailed instructions if anyone needs them.
12-20-2018 12:31 AM
@chris.thomas wrote:For anyone else that may be trying to do something similar, I would not recommend my procedure above.
Hi I am trying to do the same thing to make quad design TX/RX lanes independent to each other. I have been editing the *_init.v file as per changes recommended.
Since I am using the generated XCI how do I make to pick up my edited *_init.v file instead of the example one?
I am a bit surprised that xilinx haven't implemented an option to make the RX/TX channels independent to each other respectively. When you dig deeper no matter what you try using the IP generator you will still have shared signals.
12-20-2018 03:44 PM
Hi feldmanilia223 ,
In my case I am reading all of the generated and modified Verilog files manually then using the .xdc file for constraints. I am not using the .xci file at all, but it may be possible. I have had good luck using this method for a long time now. Let me know if you have any question on this.
Best,
Chris
12-21-2018 07:22 AM
Hi Chris
I guessed so. I am slowly working through it but if I do have any question I will ask for sure.
Thank you for getting back to me.
01-15-2019 02:18 AM - edited 01-15-2019 02:19 AM
@chris.thomas wrote:Hi feldmanilia223 ,
Best,
Chris
Hi Chris
I was performing simulation on the 4 independent GTP channels configured as per your instructions. I have noticed at around 1.32ms the clocks from the GTP module gt1_rxoutclk, gt2_rxoutclk and gt3_rxoutclk have stopped running while gt0_rxoutclk is still running I am clueless as to why. All the RXOUTCLK signals for the 4 channels start running at 15us.
Have I forgotten to set something in _gt_gt.v? Is there something I can check to understand what is going on?
01-15-2019 09:36 AM
It is a little surprising that all the clocks are running from 15us until 1.32ms - that seems like a long time without knowing what your clock rates are. Are the clock rates a consistent frequency during this whole time, i.e. are the clocks getting faster or slower between the time they start and the time they stop? If so, this might indicate that the reference clock is not toggling. Another thing to look at would be the results of the auto-phase-alignment. The auto-phase-align block for each lane has several signals worth reviewing: RUN_PHALIGNMENT, PHASE_ALIGNMENT_DONE, PHALIGNDONE. It might be worth comparing these signals between the working lane 0 and the other lanes.Below are the detailed notes I took when I went through this. It is likely that some of the signals and filenames have changed with newer versions of the Wizard, since I last did this several years ago. But at least this includes every step I took along the way from customizing the IP in the Wizard through the hand-edits to the resulting IP, hope it helps:
1.1.1.1 Customize the multi-lane IP
Component Name: gtx_quad3
1.1.1.2 GT Selection
GT Type: GTX
Shared Logic: Include shared logic in core
1.1.1.3 Line Rate, RefClk Selection
Protocol: Start from scratch
TX
Line Rate: 1 Gbps
TX off: unchecked
Reference Clock: 100 MHz
RX
Line Rate: 1 Gbps
RX off: unchecked
Reference Clock 100 MHz
Quad column: Right column
Use common DRP: unchecked
Image: Quad 0, GTX_X0Y0 + X0Y1 + X0Y2 + X0Y3, REFCLK1_Q0
PLL Selection
TX: CPLL
RX: CPLL
Transceiver selection
Use GTX X0Y12, X0Y13, X0Y14, X0Y15: checked
TX Clock source: REFCLK1_Q3
RX Clock source: REFCLK1_Q3
Advanced clocking option: unchecked
Vivado lab tools: unchecked
Active Transceivers = 4
1.1.1.4 Encoding and Clocking
TX
External Data Width: 20 bits
Encoding: None
Internal Data Width: 20 bits
RX
Encoding: None
Use DRP: checked
DRP/System Clock Frequency: 100 MHz
Optional Ports
None checked
Synchronization and Clocking
TX
Enable TX Buffer: unchecked
TX Buffer Bypass Mode: Auto
TXUSRCLK Source: TXOUTCLK
TXOUTCLK Source: Use TXPLLREFCLK checked
RX
Enable RX Buffer: unchecked
RX Buffer Bypass Mode: Auto
RXUSRCLK Source: RXOUTCLK
RXOUTCLK Source: Use RXPLLREFCLK unchecked
Optional Ports
Checked: RXPMARESET, RXCDRHOLD, TXSYSCLKSEL, RXSYSCLKSEL, CPLLPD, TXRATE, RXRATE
1.1.1.4.1 Comma Alignment and Equalization
RX Comma Alignment
Uncheck all
Termination and Equalization
Differential Swing and Emphasis Mode: Custom
RX Equalization
Mode: LPM-Auto
Automatic Gain Control: Auto
RX Termination
Voltage: Programmable
Trim Value: 800 mV
Optional Ports
Uncheck all
1.1.1.4.2 PCIe, SATA, PRBS
PCIe Express and SATA
Enable PCI Express: unchecked
SATA COM Sequence: n/a
PCI Express Parameters
Transition Time: n/a
Optional Ports
Check TXELECIDLE, TXDETECTRX, PHYSTATUS, RXSTATUS
All other unchecked
OOB signalling and PRBS
Use RX OOB Signal Detection: checked
PRBS: all unchecked
1.1.1.4.3 CB and CC Sequence
Channel Bonding
All unchecked
Clock correction
All unchecked
1.1.1.4.4 Run
Click OK until the synthesis begins. Synthesis will take several minutes to run.
1.1.1.5 Customize the single-lane IP
Component Name: gtx_quad3_lane0
1.1.1.6 GT Selection
GT Type: GTX
1.1.1.7 Line Rate, RefClk Selection
TX
Line Rate: 1 Gbps
TX off: unchecked
RX
Line Rate: 1 Gbps
RX off: unchecked
Image: Quad 0, GTX_X0Y12 (only)
PLL Selection
TX: CPLL
RX: CPLL
Use GTX X0Y12: checked
Active Transceivers = 1
1.1.1.8 Encoding and Clocking
TX
Encoding: None
RX
Encoding: None
Use DRP: checked
Optional Ports
None checked
TX
RX
Optional Ports
1.1.1.8.1 Comma Alignment and Equalization
RX Comma Alignment
Uncheck all
RX Equalization
Mode: LPM-Auto
RX Termination
Trim Value: 800 mV
Optional Ports
Uncheck all
1.1.1.8.2 PCIe, SATA, PRBS
Optional Ports
All other unchecked
PRBS: all unchecked
1.1.1.8.3 CB and CC Sequence
Channel Bonding
All unchecked
Clock correction
All unchecked
1.1.1.8.4 Run
Click OK until the synthesis begins. Synthesis will take several minutes to run. When it is complete, close Vivado.
1.1.1.8.5 Modify the IP source code
Go to the folder GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3.
Open the gtx_quad3_gt_usrclk_source.v for editing.
Find the BUFG instantiations for gt0_txoutclk and gt0_rxoutclk:
BUFG txoutclk_bufg0_i
.I (gt0_txoutclk_i),
.O (gt0_txusrclk_i)
BUFG rxoutclk_bufg1_i
.I (gt0_rxoutclk_i),
.O (gt0_rxusrclk_i)
Add the following instantiations for rx/tx clocks for gt1, gt2, and gt3 immediately after the previous instantiations:
BUFG txoutclk_bufg2_i
.I (gt1_txoutclk_i),
.O (gt1_txusrclk_i)
BUFG rxoutclk_bufg3_i
.I (gt1_rxoutclk_i),
.O (gt1_rxusrclk_i)
BUFG txoutclk_bufg4_i
.I (gt2_txoutclk_i),
.O (gt2_txusrclk_i)
BUFG rxoutclk_bufg5_i
.I (gt2_rxoutclk_i),
.O (gt2_rxusrclk_i)
BUFG txoutclk_bufg6_i
.I (gt3_txoutclk_i),
.O (gt3_txusrclk_i)
BUFG rxoutclk_bufg7_i
.I (gt3_rxoutclk_i),
.O (gt3_rxusrclk_i)
Find the assignments to the outputs that immediately follow:
assign GT0_TXUSRCLK_OUT = gt0_txusrclk_i;
assign GT0_TXUSRCLK2_OUT = gt0_txusrclk_i;
assign GT0_RXUSRCLK_OUT = gt0_rxusrclk_i;
assign GT0_RXUSRCLK2_OUT = gt0_rxusrclk_i;
assign GT1_TXUSRCLK_OUT = gt0_txusrclk_i;
assign GT1_TXUSRCLK2_OUT = gt0_txusrclk_i;
assign GT1_RXUSRCLK_OUT = gt0_rxusrclk_i;
assign GT1_RXUSRCLK2_OUT = gt0_rxusrclk_i;
assign GT2_TXUSRCLK_OUT = gt0_txusrclk_i;
assign GT2_TXUSRCLK2_OUT = gt0_txusrclk_i;
assign GT2_RXUSRCLK_OUT = gt0_rxusrclk_i;
assign GT2_RXUSRCLK2_OUT = gt0_rxusrclk_i;
assign GT3_TXUSRCLK_OUT = gt0_txusrclk_i;
assign GT3_TXUSRCLK2_OUT = gt0_txusrclk_i;
assign GT3_RXUSRCLK_OUT = gt0_rxusrclk_i;
assign GT3_RXUSRCLK2_OUT = gt0_rxusrclk_i;
Change them so that they are independent clocks for each lane:
assign GT1_TXUSRCLK_OUT = gt1_txusrclk_i;
assign GT1_TXUSRCLK2_OUT = gt1_txusrclk_i;
assign GT1_RXUSRCLK_OUT = gt1_rxusrclk_i;
assign GT1_RXUSRCLK2_OUT = gt1_rxusrclk_i;
assign GT2_TXUSRCLK_OUT = gt2_txusrclk_i;
assign GT2_TXUSRCLK2_OUT = gt2_txusrclk_i;
assign GT2_RXUSRCLK_OUT = gt2_rxusrclk_i;
assign GT2_RXUSRCLK2_OUT = gt2_rxusrclk_i;
assign GT3_TXUSRCLK_OUT = gt3_txusrclk_i;
assign GT3_TXUSRCLK2_OUT = gt3_txusrclk_i;
assign GT3_RXUSRCLK_OUT = gt3_rxusrclk_i;
assign GT3_RXUSRCLK2_OUT = gt3_rxusrclk_i;
Save this file and open the file gtx_quad3_init.v. In another window, go to the GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3_lane0 folder. Open the file gtx_quad3_lane0_init.v. The manual phase alignment blocks used in the multi-lane cores will be replaced with the automatic phase alignment blocks used in the single-lane core.
In the multi-lane file gtx_quad3_init.v, find the following code and delete it:
//Manual
gtx_quad3_TX_MANUAL_PHASE_ALIGN #
.NUMBER_OF_LANES (4),
.MASTER_LANE_ID (0)
gt0_tx_manual_phase_i
.STABLE_CLOCK (sysclk_in),
.RESET_PHALIGNMENT (U0_rst_tx_phalignment_i),
.RUN_PHALIGNMENT (U0_run_tx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt0_tx_phalignment_done_i),
.TXDLYSRESET (U0_TXDLYSRESET),
.TXDLYSRESETDONE (U0_TXDLYSRESETDONE),
.TXPHINIT (U0_TXPHINIT),
.TXPHINITDONE (U0_TXPHINITDONE),
.TXPHALIGN (U0_TXPHALIGN),
.TXPHALIGNDONE (U0_TXPHALIGNDONE),
.TXDLYEN (U0_TXDLYEN)
assign gt0_txphdlyreset_i = tied_to_ground_i;
assign gt0_txphalignen_i = tied_to_vcc_i;
assign gt0_txdlysreset_i = U0_TXDLYSRESET[0];
assign gt0_txphinit_i = U0_TXPHINIT[0];
assign gt0_txphalign_i = U0_TXPHALIGN[0];
assign gt0_txdlyen_i = U0_TXDLYEN[0];
assign U0_TXDLYSRESETDONE[0] = gt0_txdlysresetdone_i;
assign U0_TXPHINITDONE[0] = gt0_txphinitdone_i;
assign U0_TXPHALIGNDONE[0] = gt0_txphaligndone_i;
assign gt1_txdlysreset_i = U0_TXDLYSRESET[1];
assign gt1_txphinit_i = U0_TXPHINIT[1];
assign gt1_txphalign_i = U0_TXPHALIGN[1];
assign gt1_txphalignen_i = tied_to_vcc_i;
assign gt1_txphdlyreset_i = tied_to_ground_i;
assign gt1_txdlyen_i = tied_to_ground_i;
assign U0_TXDLYSRESETDONE[1] = gt1_txdlysresetdone_i;
assign U0_TXPHINITDONE[1] = gt1_txphinitdone_i;
assign U0_TXPHALIGNDONE[1] = gt1_txphaligndone_i;
assign gt2_txdlysreset_i = U0_TXDLYSRESET[2];
assign gt2_txphinit_i = U0_TXPHINIT[2];
assign gt2_txphalign_i = U0_TXPHALIGN[2];
assign gt2_txphalignen_i = tied_to_vcc_i;
assign gt2_txphdlyreset_i = tied_to_ground_i;
assign gt2_txdlyen_i = tied_to_ground_i;
assign U0_TXDLYSRESETDONE[2] = gt2_txdlysresetdone_i;
assign U0_TXPHINITDONE[2] = gt2_txphinitdone_i;
assign U0_TXPHALIGNDONE[2] = gt2_txphaligndone_i;
assign gt3_txdlysreset_i = U0_TXDLYSRESET[3];
assign gt3_txphinit_i = U0_TXPHINIT[3];
assign gt3_txphalign_i = U0_TXPHALIGN[3];
assign gt3_txphalignen_i = tied_to_vcc_i;
assign gt3_txphdlyreset_i = tied_to_ground_i;
assign gt3_txdlyen_i = tied_to_ground_i;
assign U0_TXDLYSRESETDONE[3] = gt3_txdlysresetdone_i;
assign U0_TXPHINITDONE[3] = gt3_txphinitdone_i;
assign U0_TXPHALIGNDONE[3] = gt3_txphaligndone_i;
assign U0_run_tx_phalignment_i = gt0_run_tx_phalignment_i
&& gt1_run_tx_phalignment_i
&& gt2_run_tx_phalignment_i
&& gt3_run_tx_phalignment_i
assign U0_rst_tx_phalignment_i = gt0_rst_tx_phalignment_i
|| gt1_rst_tx_phalignment_i
|| gt2_rst_tx_phalignment_i
|| gt3_rst_tx_phalignment_i
In the single-lane file gtx_quad3_lane0_init.v, copy the following code:
//Auto
assign gt0_txphalignen_i = tied_to_ground_i;
assign gt0_txdlyen_i = tied_to_ground_i;
assign gt0_txphalign_i = tied_to_ground_i;
assign gt0_txphinit_i = tied_to_ground_i;
gtx_quad3_lane0_AUTO_PHASE_ALIGN
gt0_tx_auto_phase_align_i
.RUN_PHALIGNMENT (gt0_run_tx_phalignment_i),
.PHALIGNDONE (gt0_txphaligndone_i),
.DLYSRESET (gt0_txdlysreset_i),
.DLYSRESETDONE (gt0_txdlysresetdone_i),
.RECCLKSTABLE (tied_to_vcc_i)
Paste four copies of this code into the file gtx_quad3_init.v where the old code was deleted. Update index of all signals as well as the instance names:
//Auto
assign gt1_txphalignen_i = tied_to_ground_i;
assign gt1_txphalign_i = tied_to_ground_i;
assign gt1_txphinit_i = tied_to_ground_i;
assign gt2_txphalignen_i = tied_to_ground_i;
assign gt2_txphalign_i = tied_to_ground_i;
assign gt2_txphinit_i = tied_to_ground_i;
assign gt3_txphalignen_i = tied_to_ground_i;
assign gt3_txphalign_i = tied_to_ground_i;
assign gt3_txphinit_i = tied_to_ground_i;
gtx_quad3_AUTO_PHASE_ALIGN
gt1_tx_auto_phase_align_i
.RUN_PHALIGNMENT (gt1_run_tx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt1_tx_phalignment_done_i),
.PHALIGNDONE (gt1_txphaligndone_i),
.DLYSRESET (gt1_txdlysreset_i),
.DLYSRESETDONE (gt1_txdlysresetdone_i),
gt2_tx_auto_phase_align_i
.RUN_PHALIGNMENT (gt2_run_tx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt2_tx_phalignment_done_i),
.PHALIGNDONE (gt2_txphaligndone_i),
.DLYSRESET (gt2_txdlysreset_i),
.DLYSRESETDONE (gt2_txdlysresetdone_i),
gt3_tx_auto_phase_align_i
.RUN_PHALIGNMENT (gt3_run_tx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt3_tx_phalignment_done_i),
.PHALIGNDONE (gt3_txphaligndone_i),
.DLYSRESET (gt3_txdlysreset_i),
.DLYSRESETDONE (gt3_txdlysresetdone_i),
Also, search for all occurances of the signal gt0_tx_phalignment_done_i in gtx_quad3_init.v, as it is shared with the startup state machines in the multi-lane case. This signal must be made unique to each state machine:
gt1_txresetfsm_i
.PHALIGNMENT_DONE (gt1_tx_phalignment_done_i),
gt2_txresetfsm_i
.PHALIGNMENT_DONE (gt2_tx_phalignment_done_i),
gt3_txresetfsm_i
.PHALIGNMENT_DONE (gt3_tx_phalignment_done_i),
Now do the same thing for the RX side that was just done for the TX side. In the multi-lane file gtx_quad3_init.v, find the following code and delete it:
//Manual
gtx_quad3_RX_MANUAL_PHASE_ALIGN #
.MASTER_LANE_ID (0)
gt0_rx_manual_phase_i
.RESET_PHALIGNMENT (U0_rst_rx_phalignment_i),
.RUN_PHALIGNMENT (U0_run_rx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt0_rx_phalignment_done_i),
.RXDLYSRESET (U0_RXDLYSRESET),
.RXDLYSRESETDONE (U0_RXDLYSRESETDONE),
.RXPHALIGN (U0_RXPHALIGN),
.RXPHALIGNDONE (U0_RXPHALIGNDONE),
.RXDLYEN (U0_RXDLYEN)
assign gt0_rxphdlyreset_i = tied_to_ground_i;
assign gt0_rxphalignen_i = tied_to_vcc_i;
assign gt0_rxdlysreset_i = U0_RXDLYSRESET[0];
assign gt0_rxphalign_i = U0_RXPHALIGN[0];
assign gt0_rxdlyen_i = U0_RXDLYEN[0];
assign U0_RXDLYSRESETDONE[0] = gt0_rxdlysresetdone_i;
assign U0_RXPHALIGNDONE[0] = gt0_rxphaligndone_i;
assign gt1_rxdlysreset_i = U0_RXDLYSRESET[1];
assign gt1_rxphalign_i = U0_RXPHALIGN[1];
assign gt1_rxphalignen_i = tied_to_vcc_i;
assign gt1_rxphdlyreset_i = tied_to_ground_i;
assign gt1_rxdlyen_i = tied_to_ground_i;
assign U0_RXDLYSRESETDONE[1] = gt1_rxdlysresetdone_i;
assign U0_RXPHALIGNDONE[1] = gt1_rxphaligndone_i;
assign gt2_rxdlysreset_i = U0_RXDLYSRESET[2];
assign gt2_rxphalign_i = U0_RXPHALIGN[2];
assign gt2_rxphalignen_i = tied_to_vcc_i;
assign gt2_rxphdlyreset_i = tied_to_ground_i;
assign gt2_rxdlyen_i = tied_to_ground_i;
assign U0_RXDLYSRESETDONE[2] = gt2_rxdlysresetdone_i;
assign U0_RXPHALIGNDONE[2] = gt2_rxphaligndone_i;
assign gt3_rxdlysreset_i = U0_RXDLYSRESET[3];
assign gt3_rxphalign_i = U0_RXPHALIGN[3];
assign gt3_rxphalignen_i = tied_to_vcc_i;
assign gt3_rxphdlyreset_i = tied_to_ground_i;
assign gt3_rxdlyen_i = tied_to_ground_i;
assign U0_RXDLYSRESETDONE[3] = gt3_rxdlysresetdone_i;
assign U0_RXPHALIGNDONE[3] = gt3_rxphaligndone_i;
assign U0_run_rx_phalignment_i = gt0_run_rx_phalignment_i
&& gt1_run_rx_phalignment_i
&& gt2_run_rx_phalignment_i
&& gt3_run_rx_phalignment_i
assign U0_rst_rx_phalignment_i = gt0_rst_rx_phalignment_i
|| gt1_rst_rx_phalignment_i
|| gt2_rst_rx_phalignment_i
|| gt3_rst_rx_phalignment_i
//Auto
assign gt0_rxphalignen_i = tied_to_ground_i;
assign gt0_rxdlyen_i = tied_to_ground_i;
assign gt0_rxphalign_i = tied_to_ground_i;
gt0_rx_auto_phase_align_i
.RUN_PHALIGNMENT (gt0_run_rx_phalignment_i),
.PHALIGNDONE (gt0_rxphaligndone_i),
.DLYSRESET (gt0_rxdlysreset_i),
.DLYSRESETDONE (gt0_rxdlysresetdone_i),
.RECCLKSTABLE (gt0_recclk_stable_i)
//Auto
assign gt1_rxphalignen_i = tied_to_ground_i;
assign gt1_rxphalign_i = tied_to_ground_i;
assign gt2_rxphalignen_i = tied_to_ground_i;
assign gt2_rxphalign_i = tied_to_ground_i;
assign gt3_rxphalignen_i = tied_to_ground_i;
assign gt3_rxphalign_i = tied_to_ground_i;
gt1_rx_auto_phase_align_i
.RUN_PHALIGNMENT (gt1_run_rx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt1_rx_phalignment_done_i),
.PHALIGNDONE (gt1_rxphaligndone_i),
.DLYSRESET (gt1_rxdlysreset_i),
.DLYSRESETDONE (gt1_rxdlysresetdone_i),
.RECCLKSTABLE (gt1_recclk_stable_i)
gt2_rx_auto_phase_align_i
.RUN_PHALIGNMENT (gt2_run_rx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt2_rx_phalignment_done_i),
.PHALIGNDONE (gt2_rxphaligndone_i),
.DLYSRESET (gt2_rxdlysreset_i),
.DLYSRESETDONE (gt2_rxdlysresetdone_i),
.RECCLKSTABLE (gt2_recclk_stable_i)
gt3_rx_auto_phase_align_i
.RUN_PHALIGNMENT (gt3_run_rx_phalignment_i),
.PHASE_ALIGNMENT_DONE (gt3_rx_phalignment_done_i),
.PHALIGNDONE (gt3_rxphaligndone_i),
.DLYSRESET (gt3_rxdlysreset_i),
.DLYSRESETDONE (gt3_rxdlysresetdone_i),
.RECCLKSTABLE (gt3_recclk_stable_i)
Also, search for all occurances of the signal gt0_rx_phalignment_done_i in gtx_quad3_init.v, as it is shared with the startup state machines in the multi-lane case. This signal must be made unique to each state machine:
gt1_rxresetfsm_i
.PHALIGNMENT_DONE (gt1_rx_phalignment_done_i),
gt2_rxresetfsm_i
.PHALIGNMENT_DONE (gt2_rx_phalignment_done_i),
gt3_rxresetfsm_i
.PHALIGNMENT_DONE (gt3_rx_phalignment_done_i),
Finally, find and delete the following signal declarations in gtx_quad3_init.v:
// --------------------------- TX Buffer Bypass Signals --------------------
wire mstr0_txsyncallin_i;
wire [3 : 0] U0_TXDLYEN;
wire [3 : 0] U0_TXDLYSRESET;
wire [3 : 0] U0_TXDLYSRESETDONE;
wire [3 : 0] U0_TXPHINIT;
wire [3 : 0] U0_TXPHINITDONE;
wire [3 : 0] U0_TXPHALIGN;
wire [3 : 0] U0_TXPHALIGNDONE ;
wire U0_run_tx_phalignment_i;
wire U0_rst_tx_phalignment_i;
// --------------------------- RX Buffer Bypass Signals --------------------
wire rxmstr0_rxsyncallin_i;
wire [3 : 0] U0_RXDLYEN;
wire [3 : 0] U0_RXDLYSRESET;
wire [3 : 0] U0_RXDLYSRESETDONE;
wire [3 : 0] U0_RXPHALIGN;
wire [3 : 0] U0_RXPHALIGNDONE ;
wire U0_run_rx_phalignment_i;
wire U0_rst_rx_phalignment_i;
Now, delete the multi-lane files:
GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3/gtx_quad3/example_design/gtx_quad3_rx_manual_phase_align.v
GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3/gtx_quad3/example_design/gtx_quad3_tx_manual_phase_align.v
Copy the file:
GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3_lane0/gtx_quad3_lane0/example_design/gtx_quad3_lane0_auto_phase_align.v
To:
GTX_Wizard_run/GTX_Wizard_Project/GTX_Wizard_Project.srcs/sources_1/ip/gtx_quad3/gtx_quad3/example_design/gtx_quad3_auto_phase_align.v
Go to the folder:
And open the file gtx_quad3_auto_phase_align.v
Find and replace the string “gtx_quad3_lane0” with “gtx_quad3” (5 occurrences)
Save and close.
Go back to the folder:
Open the file gtx_quad3_multi_gt.v
Search for the string “PCS_RSVD_ATTR_IN” and replace the lines (4 occurrences):
.PCS_RSVD_ATTR_IN (48'h000000000106),
with:
.PCS_RSVD_ATTR_IN (48'h000000000100),
Save and close.
