jumper_qb
GTX Rx show radom data when not connected
I found one confusing things during debugging the GTX,
when I discconect the GTX Rx, no coming signal on Rx. in chipscope, gt_rxdata_i,(gt_rxusrclk2) the parallel data, will shows radom data. e.g
5555555555555,  aaaaaaaaaaaaaaaa, 55a5a55a.....etc..
How could that happen?
Caleb-
balkris
I think this is not random data.
The GTP receiver includes a built-in PRBS checker. This checker can be set to check for one of three industry-standard PRBS patterns. The checker is self-synchronizing and works on the incoming data before comma alignment or decoding. This function can be used to test the signal integrity of the channel
Thanks and Regards
Balkrishan
ashishd
Hello @jumper_qb,
Can you let us know the steps you followed which made you observe this behavior?
Ashish
venkata
Can you check if this is because of crosstalk? Can you probe RXOUTCLK output from GT in this scenario?
Whether this data is consistent? or found in some duration only.
