Generating MCS file with two bitstreams causes error
Hello all,
I'm using Vivado 2018.2 to try to load two bit files into one mcs file so that I can test out the multi boot functionality of an Artix 7.  I'm running into a problem when I try to generate the mcs file using two bit files.  With one bit file the mcs file generates correctly.
I have my two configurations(IE bit files) then I go to 'Tools>Generate Memory Configuration File' and put my two bit files in then press 'OK'.  It runs the TCL command but then it generates the following error:
ERROR: [Writecfgmem 68-6] Cannot parse string "up 0x00000000 "C:/Users/CampbellDy/icap_test/icape2_test.bit" up 0xF0000000 "C:/Users/CampbellDy/icap_test/icape2_test_1s.bit"".
Correct format is "up|down 0x0 bitfile.bit <bitfile2.bit>".
The TCL command generated from the wizard is:
write_cfgmem  -format mcs -size 16 -interface SPIx1 -loadbit {up 0x00000000 "C:/Users/CampbellDy/icap_test/icape2_test.bit" } -file "C:/Users/CampbellDy/icap_test/icape2_test.mcs"
I can't seem to find much info on the write_cfgmem command.  What I did find looks pretty similar to the above.  I tried messing with it to remove the curly brackets to fit the format I found but that didn't seem to work either.
What am I doing wrong here?  It might be something with my setup in the wizard as this is the first time I'm attempting a multiboot flash.
I appreciate the help!
Hi Dylan,
Thanks for sharing the details. This error is coming because you are going out of the range for flash which you are using. Max address for this flash is 00FFFFFF. If you use any address within that range it should generate the file for you.
Here is the details from the PRM file
Configuration Memory information
File Format MCS
Interface SPIX1
Size 16M
Start Address 0x00000000
End Address 0x00FFFFFF
Harshit
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
You can edit the below command as required:
write_cfgmem  -format mcs -size 128 -interface BPIx16 -loadbit {up 0x00000000 "C:/harshit/configuration/design_forum.bit" up 0x0F000000 "C:/harshit/configuration/design_forum_bpi.bit" } -file "C:/design/test.mcs"
Hi harshit,
I used the Write Memory Configuration File window that you show and that is how I get my error.
Just to make sure I took your TCL command and edited for my situation.  So I used the below TCL command:
write_cfgmem  -format mcs -size 16 -interface SPIx1 -loadbit {up 0x00000000 "C:/Users/CampbellDy/icap_test/icape2_test.bit" up 0xF0000000 "C:/Users/CampbellDy/icap_test/icape2_test_fast.bit" } -file "C:/Users/CampbellDy/icap_test/icap_test.mcs"
It's the same as yours except the file locations are different, size is 16 and the interface is SPIx1.  I still get the same error as I did in the original post.
ERROR: [Writecfgmem 68-6] Cannot parse string "up 0x00000000 "C:/Users/CampbellDy/icap_test/icape2_test.bit" up 0xF0000000 "C:/Users/CampbellDy/icap_test/icape2_test_fast.bit"".
Below is the configuration I used in case it's useful.
With this config I still get the error.
Thank you,
Dylan
Hi Dylan,
File Format MCS
Interface SPIX1
Size 16M
Harshit
Hi harshit,
Thank you again for the help.  You're correct, the address was my problem.  For some reason I thought that the zero in the config dialog represented the max size of the flash.  And then the error shown seemed to be indicating a syntax error.
Thanks for showing me that PAR file.  That makes planning the space much easier than what I was doing previously.
Thank you!
