ismailci
Generic Bitstream for Partial Regions
Hi all,
I am using ZC702 Zynq board. I work with partial reconfiguration. With multiple regions, I generate multiple bitstreams. Is there a way to change partial bitstream's implementation region?
For example, I created 2 partial regions. I left one of them empty. Can I change non-empty region's partial bitstream so that it can work on other region?
When I tried to open bitstreams with Notepad, it does not work. I thought changing some offsets in bitstreams but bitstreams cannot be edited.
Is there a feature of Vivado that can let me generate generic partial bitstream or generate partial bitstreams impelemented in every region usign one design file?
İsmail
bpatil
Hello @ismailci
I believe note from UG909 : Page 120 provided below will provide you necessary details:
Please also check AR#63419; and UG909 (Page 122 ~125) for detailed understanding of bistreams used for partial reconfiguration.
Bhushan
