albano_fds1
HC-SR04
Buenas tardes, estoy realizando un proyecto el cual debe leer el sensor hc-sr04 y mostrar la distancia en un display. No logro realizar la maquina de estados y quisiera saber si alguien me puede dar una mano o con codigo, lo debo hacer en verilog. Muchas gracias!
jheslip
@albano_fds1 the majority of the forum members communicate through English so if you can write in English that will get you the most help. This is what i get when i try and translate the question, i hope it is accurate:
"Good afternoon, I'm doing a project which should read the hc-sr04 sensor and show the distance in a display. I can not make the state machine and I would like to know if someone can give me a hand or with a code, I must do it in verilog. Thank you!"
i don't think anyone will volunteer to do you work for you, i would suggest giving it a go and if you have problems with the state machine design we can try and help with specific questions.
