11-25-2018 11:40 AM
Hi Friends,
I am getting hold violation on reset net, this reset is static signal indirectly this is am providing from VIO at top level. but internally this is connected to FF.
Can i neglect this violation ?
When we can ignore the hold violations ?
what modifications we have to do to overcome hold violations ?
hold violation
NOTE: Any help or suggestions are highly appreciated.
Thank you
S Sampath
11-25-2018 05:26 PM
From your reset name (poreset = power-ON reset?), it appears you are sending a power-ON reset to the various components of your design. Often, power-ON resets are asynchronous and they cross clock-domains - both of which can cause timing analysis problems.
Usually, a circuit called a reset-bridge is used to bring the power-ON reset into each clock-domain. That is, a separate reset-bridge is needed for each clock domain. The reset-bridge causes the reset in each clock-domain to go ON simultaneously with the power-ON reset and to come OFF synchronously with the clock in the clock-domain. The reset-bridge also acts as a synchronizer and should prevent the timing analysis problems you are seeing. You’ll find details of the reset-bridge and other discussion of resets in <this> post.
Mark
