How do you set IOB=FALSE for register in XDC file?
How do you set the IOB=FALSE for a register in the XDC constraints file?
The register is 'system_i/axi_ethernetlite_0/U0/IOFFS_GEN2.DVD_FF'
and I gather that the syntax is something like this: set_property IOB FALSE [something goes here]
Re: How do you set IOB=FALSE for register in XDC file?
The correct argument here is get_cells since the property is applied to the flip flop
set_property IOB FALSE [get_cells system_i/axi_ethernetlite_0/U0/IOFFS_GEN2.DVD_FF]
