How to accommodate One PCI express and Two SGMII into Zync-7000 XC7Z015?
There is only one GT_COMMON module in the Tranceiver Quad. I have to make clock generation module reside in one core.  If I set "share logic in the core" in PCIE generation wizard, how to connect clock networks to other two SGMII interfaces ?
I have problem in access support portal. I don't know if this board is appropiate for Zynq device question.
You can generate SGMII cores with "Shared logic in example" option.
