ssampath
Voyager
Voyager
How to choose Ethernet IP pin locs ?
Hi Friends,
We are going to implement a custom board with Ethernet on it and we are using Xilinx kintex ultra FPGA part. How to choose pin constraints for Ethernet.
I don't have any idea on Ethernet, pls help in this.
1) what are the modules i have to consider on the board to implement Ethernet ?
2) what is the Xilinx IP for controlling the Ehternet IP ?
3) How to choose PIN constraints as well ?
NOTE: Any suggestions or help is highly appreciated.
Thank You
S Sampath
-Sampath
kgadde
Hi @ssampath
Which Ethernet IP you want to use for Kintex Ultrascale device.
You can check with the available IP list in the below page:
https://www.xilinx.com/products/technology/ethernet.html
ssampath
Voyager
Voyager
HI @kgadde,
We are using,  Ethernet 1G/2.5G Ethernet PCS/PMA or SGMII.
Thank You
S Sampath
-Sampath
kgadde
Hi @ssampath
I believe you can refer KCU105 design for this purpose.
https://www.xilinx.com/products/boards-and-kits/kcu105.html#hardware
