How to generate SPI protocols already present inside Processing system ?
We are trying to generate the SPI protocols signals from the Zybo-Z710 board, which uses Zynq-7000 SoC. Since, the PS section of the chip contains two SPI modules. Can anyone tells me the procedure for activating the SPI line inside the PS.
I want to use this SPI lines to transfer data and provide control to the another module.
AMOL
Basicaly , you need to instantiate from the tools the SPI you want to use, and ensure those pins on your board are free for SPI,
Software wise, you instantiate the C routines that come when the IP is instantiated.
I'd guess, as you are asking this, you are new to configurable Processors like the Zynq. Once you have done a few setups its fairly intuitive, till then its like swimming in syrup.
Can I suggest you work your way through these
https://www.avnet.com/opasdata/d120001/medias/docus/3/SILICA_Xilinx_Zynq_ZedBoard_Vivado_Workshop_ver1.0.pdf
https://www.xilinx.com/support/answers/69276.html
https://www.udemy.com/course/zynq-training-learn-zynq-7000-soc-device-on-microzed-fpga/
Is anythere need to use Petalinux application in this ?
AMOL
You dont have to use an OS to run the Zynq,
you can also run it "bare metal , native C coode
https://www.xilinx.com/support/documentation/application_notes/xapp1079-amp-bare-metal-cortex-a9.pdf
Ok!  Last question. I Made all the SPI as exetrnal interfaces. Can you how to connect it to the EMIO pins.
I am using Viavdo 2019, my block diagram is looking like thisScreenshot (8).png
Amol
