How to implement log10 (x) in verilog in Vivado?
Hello all,
I want to write a variable in decibels. So I need to do variable = 10*log10(x).
How to implement log10 on Verilog for Vivado?
Please help.
Shruthi Sampathkumar.
Tags (3)
Sorry I don't have FPGA code handy, but I have implemented a fixed point integer logarithm on small microprocessors.  I used a successive approximation algorithm similar to CORDIC.  http://www.quinapalus.com/efunc.html <= is where I found the basic algorithm.  In my case, I built a Log2() function covering an input range of 1 to 2 with a prescaling loop to find the integer portion of the answer.  Then I used the change of base formula to convert any logarithm to Log2(). example: 10*log10(x) = 10/log2(10)*log2(x).  Gave about 1-bit per loop and I would expect a state machine implementing it to be pretty simple.
Also found this quick discussion that links to a few other algorithms in current use for calculating logarithms. What algorithm is used by computers to calculate logarithms?
Marty
A lookup table is common for this, depending on your requirements.
www.xilinx.com
Marty
How the lookup table method is used to implement log10 (x) in verilog. Please give me some example?
