mengxiang1326725
How to improve the warning or error level of vivado especially using verilog?
Hello, everyone!
  I always use verilog. I found that the vivado won't tell you a critical warning or error that you don't declare the reg or wire but you use them in your program when you program with verilog. So, I just want to know if there is a way that made the vivado to tell you a error in the above case.
 Thanks!
Gu, Yue.
pratham
@mengxiang1326725 Yes, there is a way to do this using gui or tcl
Using tcl:
[BD 41-702] Propagation TCL tries to overwrite USER strength parameter C_S_AXI_MEM_ID_WIDTH(4) on '/axi_emc_0' with propagated value(0). Command ignored
set_msg_config -id {BD 41-702} -new_severity {ERROR}
Just change the message ID with the Id number of warning/message which you wish to change to an error.  In the above example BD 41-702 is just a warning which would be changed to error after running above tcl command.
-Pratham
balkris
can you give me example . I think vivado should give warning in above case
Thanks and Regards
Balkrishan
pratham
Using tcl:
-Pratham
balkris
To change the severity of a particular message, use the Tcl command "set_msg_severity".
Type "set_msg_severity -help" in the Tcl console or in a Vivado Tcl shell to get the complete command description and syntax.
The possible severities for a message and their general definitions are:
ERROR - An ERROR condition implies an issue has been encountered which will render design results unusable and cannot be resolved without user intervention.
CRITICAL WARNING - A CRITICAL WARNING message indicates that certain input/constraints will either not be applied or are outside the best practices for a FPGA family. User action is strongly recommended.
Note: Since this is a two word value, it must be enclosed in {} or "".
WARNING - A WARNING message indicates that design results may be sub-optimal because constraints or specifications may not be applied as intended. User action may be taken or may be reserved.
INFO - An INFO message is the same as a STATUS message, but includes a severity and message ID tag. An INFO message includes a message ID to allow further investigation through answer records if needed.
STATUS - A STATUS message communicates general status of the process and feedback to the user regarding design processing. A STATUS message does not include a message ID.
Every message delivered by the tool has a unique global message ID that consists of an application sub-system code and a message identifier. This results in a message ID that looks like the following:
"Common 17-54"
"Netlist 29-28"
"Synth 8-3295"
Use this command to customize the message severity returned by the tool to specific levels appropriate to your usage.
Note: You can restore the message severity of a specific message ID to its original setting with the reset_msg_severity command.
Examples:
The following example reduces or downgrades the significance of message ID "Common 17-54" from a CRITICAL WARNING to a WARNING so that it causes less concern when encountered:
set_msg_severity "Common 17-54" WARNING
The following example elevates or upgrades a common INFO message to a Critical Warning:
set_msg_severity "Common 17-81" "CRITICAL WARNING"
The severity of a DRC check can be set using the set_property command.
Example: Run the below command in Tcl console of Vivado to set the severity of "NSTD-1" to Warning
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
Thanks and Regards
Balkrishan
balkris
check these ARs as well
http://www.xilinx.com/support/answers/54799.html
http://www.xilinx.com/support/answers/53034.html
Thanks and Regards
Balkrishan
gszakacs
Instructor
Instructor
If you don't declare a reg, you should gen an error if you make assignments to that reg in a process (always or initial block).  If you don't declare a wire, Verilog defaults to automatically declaring a (single) wire with that name.  You can override the default Verilog behavior using `default_nettype.  Note that this is a global switch like a macro definition, so to prevent issues with other code, you should reset it to the default at the end of your source file.  Example:
// Place outside of module
`default_nettype none
module foo
  input wire clk,  // inputs and outputs no longer have a default "wire" type, so you need to write it explicitly
  output reg Q,
  output wire bar
endmodule
// Outside module declaration, return default nettype to its default of "wire"
`default_nettype wire
-- Gabor
