How to input analog siglnal into XADwizard with verilog simulation?
I want to simulate XADwizard I with verilog testbench in Vivado. I wrote as below for analog input sigmal to XADwizard terminal "Vp_Vn". But it didn't work. The analog signal seemed not to be input XADwizard. How should I input analog signal to the terminal "Vp_Vn"? ----------------------------------------------------------------------------------- real sin_out; parameter pi = 3.1415926535; parameter freq = 100e5; sin_out = $cos( 2 * pi * freq * t ) XADC_MODULE_wrapper DUT_1 (.sys_clock(CLK), .reset(RST), .Vp_Vn_0_v_n(1'b0), .Vp_Vn_0_v_p(sin_out), .do_out_0(OUT)); ---------------------------------------------------------------------------------------------------------------------------------------------------------------
Re: How to input analog siglnal into XADwizard with verilog simulation?
Hi @takimoto
Use the Analog Stimulus file , this included  analog input values for simulation.
Please check the example test bench section in below user guide to create a analog stimulus file  page 88
https://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
Hi  pthakare
Thank you for advicing kindly.
I tried to Analog stimulus file for analog signals to  terminals "VP" "VP" at XADC wizard.
I made  a file design.csv and wrote testbench as attached. But it did not work. The analog signals were not be input to the module terminals. "VP" "VN" terminal signal at XADC wizard became High impedance(Z).
What is wrong? Would you give some more advice?
Hi  pthakare
I could not attached design.csv. So I attach again.
Hi @takimoto
Is it feasible to share me your project archive ? I will send you the FTP link to attach the same.
Additionally for the refference , with the same IP configuration , generate the example design (Right click to Ip-> open example design) and check the testbench to see what you are missing
or
Simulate the example deisgn in UG480 and then make the changes for VP/VN
Hi pthakare,
Than you for replay.
Please check the attached archive. This is the project I want to work.
I reffered the example design generated from XADC IP configuration, but still I have not be able to find the solution.
I'm glad for your help.
Hi @takimoto
Thanks for sharing the project , I will check this at my end and get back to you shortly
