07-25-2018 04:36 AM
I am using Kintex custom board [xc7k160tffg676-2] and Cyclone V FPGA board for one-way communication. I am trying to send lvds2.5v signal from Cyclone V FPGA board as input to lvds3.3v Kintex custom board. The grounds of the two boards are connected together. But i am unable to see any LVDS signals in ILA [Kintex custom board].
How to interface the lvds3.3v signal with lvds2.5v of Cyclone V FPGA board?Please suggest me ?
07-25-2018 06:02 AM
Have you got off-chip termination for the LVDS lines? The 7-series does not really have LVDS33 support like some older families did. They have LVDS25 support and that still works even if you power the I/O bank at 3.3V - but the on-chip LVDS termination does not work in this mode. If you want on-chip termination, you must power the I/O bank at 2.5V.
07-25-2018 03:54 PM
Thaus_015,
One of the mantra's here if it's not perfectly clear from the data sheet itself is to just run a quick point to point ibis simulation modeling the proper IO buffers for each part. If you want to be on the safe end I always suggest making sure you are using a external differential termination. Not only is it needed for VCCOs other than the one specced for the LVDS IOSTANDARD but generally it should also more precise over PVT than DIFF_TERM.
Tezz
07-25-2018 09:44 PM
Thanks for your response. How to create IBIS simulation model ? The below steps are i need to follow. Please explain me
To Generate an IBIS Model In the Design panel, select Implementation from the Design View drop-down list. Image In the Hierarchy pane, select the top module Image. In the Processes pane, expand Implement Design. Do one of the following: For an FPGA design, expand Place & Route. For a CPLD design, and expand Optional Implementation Tools. Optional. Right-click the Generate IBIS Model process, and select Process Properties to set the IBIS Model Generation Properties. Double-click Generate IBIS Model.
07-26-2018 02:36 AM
@thaus_015 Check this IBIS Model Generation guide from UG899
You haven't though answered the query asked above if you have a 100 ohm external termination on your Kintex board? Can you share that information or show the schematic section of this part?
07-26-2018 02:58 AM
we have not mounted differential termination resistors externally instead we using the following command
set_property DIFF_TERM TRUE [get_ports {}]
07-26-2018 03:07 AM
@thaus_015 Is the bank VCCO 2.5V? If not, setting DIFF_TERM on a non-2.5V Bank is unsupported configuration for LVDS_25 IO Std.
07-26-2018 03:17 AM
Yes, 2.5 V only.
trigger pin [KINTEX custom board] is 3.3 v
But Trigger pin [Cyclone V FPGA board ] is 2.5 V [I/o} standard
07-26-2018 05:01 AM
I need to pass LVDS signals of Cyclone V FPGA board to LVDS input of KINTEX custom board.
I/0 Standard(LVDS) of Cyclone V FPGA board is LVDS
I/O Standard (LVDS) of KINTEX custom board i LVDS and LVDS_25
How to interface I/O standard of Cyclone V FPGA board to I/O standard of KINTEX custom board ? Please anyone suggest me ?
07-26-2018 05:39 AM
Have you got off-chip termination for the LVDS lines? yes
I am working with KINTEX custom board [DAQ] : I/O standard [LVDS] is LVDS and LVDS_25
and Cyclone V FPGA board :I/O standard [LVDS] is LVDS.
07-26-2018 05:40 AM
You need to answer @gnarahar's question. What is the voltage connected to VCCO on the banks that you are using to receive the LVDS?
07-26-2018 05:44 AM
Please look_over the attachment.
2.5 V and 1.8 v for LVDS
07-27-2018 12:07 AM
@thaus_015 I believe we need to get a few things clarified here as I am a bit confused from some of the information you posted in the last 2 responses
07-27-2018 03:08 AM
1 I am sending trigger signal From Cyclone V board to Kintex custom board. For every 500ns, trigger signal will be high/on-time.
2. Trigger Pin [Cyclone Fpga] =I/O standard 2.5v
clock_50 {cyclone FPGA] = I/O standard 2.5v
LVDS Ports=I/O standard is LVDS
4 How are you connecting the 2 boards? Through Flat ribbon cable
07-27-2018 05:04 AM
>>Can you probe them externally and check if you are receiving the signals at the Kintex side and share those scopeshots?
at the Kintex side, externally i probe the signals i am getting the signals only at pin which has LVDS I/O standard but not at the pins which have LVDS_25 I/O standard.
