How to parse LVDS differential input signal to a differential output?
  How to parse LVDS differential input signal to a differential output in terms of verilog code?
Re: How to parse LVDS differential input signal to a differential output?
More like:
// a general idea - might have syntax errors
// see ug953 for more info.
module myTest (
    input wire RX0_P,
    input wire RX0_N,
    output wire TX0_P,
    output wire TX0_N,
wire  rx0;
IBUFDS ibuf_rx0 (
   .I   (RX0_P),
   .I_B (RX0_P),
   .O   (rx0)
OBUFDS obuf_tx0 (
   .I    (rx0),
   .O    (TX0_P),
   .O_B  (TX0_N)
endmodule
sort of. They should still be defined as LVDS... but you can use an IBUFDS to from differential to single ended and then wire them directly to an OBUFDS.
You should really download the Series 7 Libraries and the SelectIO userguides.
And keep in mind, in the simplest form above, you may introduce delay artifacts that have to be compensated for.
You haven't really supplied a lot of information about the video source or receiver. So -- all this is dependant on testing.
Could you be more specific? (BTW, there are a lot of fun LVDS Xappnotes available)
Next - download the SelectIO user guide and the series 7 libraries userguide.
You will want to look up
IDELAY and ODELAY
ISERDES and OSERDES
Are you asking how to look at the data?
Without more info --
Getting the data IN:
 Configure your input ports for LVDS Input and connect that to the input of an ISERDES unit (optionally through an IDELAY unit).
 You haven't mentioned how clocking is supplied and that needs to be considered -- so make sure to check Xappnotes for LVDS examples to see how to deal with clocking.
Getting the data OUT:
  Connect your parallel data stream (and clocking) to an OSERDES unit (optionally through an ODELAY unit if you need it) to a IOpad configured for LVDS output.
And there ya go.
I know -- not a lot of detail -- but you need to supply us with detail for us to do the same in return.
Cheers,
 -Ben
Hi Ben,
  Thanks for the response. Here are more details of my project.
On the hardware (PCB), I have these LVDS signals coming into the FPGA (Spartan 7) which are physically connected to these IOs (bank34) of the FPGA:
RX0_P, RX0_N connected to IO_L8P_T1_34 and IO_L8N_T1_34
RX1_P, RX1_N connected to IO_L10P_T1_34 and IO_L10N_T1_34
RX2_P, RX2_N connected to IO_L1P_T1_34 and IO_L1N_T1_34
RX3_P, RX3_N connected to IO_L7P_T1_34 and IO_L7N_T1_34
CLK_P, CLK_N connected to IO_L12P_T1_MRCC_34 and IO_L12N_T1_MRCC_34
 Without making any modifications to the LVDS signals, how do I parse the signal into another set of FPGA IOs in bank14 ?
RX0_P, RX0_N signal to IO_L8P_T1_ D11_14 and IO_L8N_T1_ D12_14
RX1_P, RX1_N signal to IO_L10P_T1_ D14_14 and IO_L10N_T1_ D15_14
RX2_P, RX2_N signal to IO_L7P_T1_ D09_14 and IO_L7N_T1_ D10_14
RX3_P, RX3_N signal to IO_L13P_T2_ MRCC_14 and IO_L13N_T2_ MRCC_14
CLK_P, CLK_N signal to IO_L12P_T1_ MRCC_14 and IO_L12N_T1_ MRCC_14
   On the PCB, these bank14 IOs are connected to the LCD screen connector.
Basically, I just want to wire the incoming LVDS signals in bank34 to the output IOs in bank14.
Thanks!
@vivienwwp wrote:
Hi Ben,
If you're just making a repeater, you just wire the inputs to the outputs.
You'd probably be better off keeping all inputs and outputs on the same I/O bank for minimum and constrainable latency.
Hi Ben
  Do you mean not defining these IOs as differential but just regular IO LVCMOS25?
   just do this:
module myTest(
input wire RX0_P
input wire RX0_N
output wire TX0_P
output wire TX0_N
  assign TX0_P = RX0_P;
  assign TX0_N = RX0_N;
endmodule
More like:
module myTest (
    input wire RX0_P,
    input wire RX0_N,
    output wire TX0_P,
    output wire TX0_N,
wire  rx0;
IBUFDS ibuf_rx0 (
   .I   (RX0_P),
   .I_B (RX0_P),
   .O   (rx0)
OBUFDS obuf_tx0 (
   .I    (rx0),
   .O    (TX0_P),
   .O_B  (TX0_N)
endmodule
Thanks Ben! I'll try it out soon on Vivado and see if it works.
Hi Ben
I was just wondering how different is using IBUFDS and OBUFDS to using a IBUFDS_DIFF_OUT ?
In IBUFDS_DIFF_OUT , can the O and OB outputs be connected to a top level port in the design or is it only a buffer internally?
By the way, I ran a behavioural simulation and I get the expected waveform.
@vivienwwp wrote:
Hi Ben
Well, the I and O prefix are input|output respectively. Both use single ended signals internally.
The IBUFDS_DIFF_OUT give the designer internally inverted signals in case the design needs it for something.
Technically, you could use an IBUFDS_DIFF_OUT in your schematic above, but the .OB port isn't needed for the OBUFDS... but maybe you could connect it elsewhere for some other design need..
Hi Ben
  I finally had the hardware to test the code. The repeater code didn't work at all.
The IBUFDS and OBUFDS design yielded some results but not great. The LCD screen was showing distorted lines.
   The design is exactly as shown in the schematic. What do you think is the problem? Do you i need to set DIFF_TERM to true? I do not have 100 ohm termination between P and N at the inputs on the physical board. I also do not have 100 ohm termination between P and N at the outputs.
