How to set ODELAYE2 REFCLK_FREQUENCY Attribute
I used the SelectIO wizard (5.1) to configure an output port with a DDR 8:1 SERDES and an ODELAYE2 with variable loadable delay.  The delay reference clock is running at 400 MHz.
When I compile this I get a critical warning:
CRITICAL WARNING: [Timing 38-469] The REFCLK pin of IDELAYCTRL gateDrivers/genblk1[0].gateDriver_i/gateDriverSelectIO_i/inst/delayctrl has a clock period of 2.500 ns (frequency 400.000 Mhz) but ODELAYE2 gateDrivers/genblk1[0].gateDriver_i/gateDriverSelectIO_i/inst/pins[0].odelaye2_bus has REFCLK_FREQUENCY of 200.000 Mhz (period 5.000 ns). The IDELAYCTRL REFCLK pin frequency must match the ODELAYE2 REFCLK_FREQUENCY property.
I see no way in the wizard to change the ODELAYE2 REFCLK_FREQUENCY attribute.   How is this supposed to be accomplished?  I've tried editing pinDriverSelectIO_selectio_wiz.v by hand but even then I get the critical warning.
Re: How to set ODELAYE2 REFCLK_FREQUENCY Attribute
Hi @norume
In this case I tried it with a simple example.
There is no attribute on the IDELAYCTRL to set the reference clock. In this case it should be set by the create_clock at the reference clock input.
It seems by default the wizard set the refclk property on the ODELAY to be 200MHz.
So to get it all to work I set this in the synthesised netlist.
set_property REFCLK_FREQUENCY 400 [get_cells io_inst/inst/odelaye2_bus]
set_property REFCLK_FREQUENCY 400 [get_cells {io_inst/inst/pins[0].odelaye2_bus}]
set_property REFCLK_FREQUENCY 400 [get_cells {io_inst/inst/pins[1].odelaye2_bus}]
set_property REFCLK_FREQUENCY 400 [get_cells {io_inst/inst/pins[2].odelaye2_bus}]
set_property REFCLK_FREQUENCY 400 [get_cells {io_inst/inst/pins[3].odelaye2_bus}]
create_clock -period 2.500 -name ref_clock [get_ports ref_clock]
It goes through the tools fine then.
Keith
Hi @norume
I think (but I would need to double check) that support for 400mhz reference clock was added pretty late so my guess would be that this is some kind of mismatch in the wizard.
I would need to try this.
A potential way to workaround it would be to do a set_property on the ODELAY in the netlist. Give that a try for now and see if it works.
Keith
Hi @norume
Keith
Thanks.  I'll do that for now.
Hopefully an updated version of the wizard will take care of this too.
