Visitor dabangking
How to set the SLEWRATE of FPGA?
How to set the  SLEWRATE of FPGA in constraint file(for example, virtex 7)?
Re: How to set the SLEWRATE of FPGA?
Hi @dabangking
You can set Slew rate attributes ‘ FAST’ and ‘SLOW’ in xdc as below.
set_property SLEW FAST|SLOW [get_ports port_name]
Refer UG471 for more info.
Rohit
Hi @dabangking
Rohit
