dabangking
How to use 《7_Series_XPE.xls》to estimate logical resource?
After select a device, how to set the "Quick estimate" parameter?
for example, logical clock is 368.64MHz, and logical sampling frequency is 46.08MHz,how to set the “Design Activity”?
Thanks!
ddn
Hi @dabangking,
Design Activity :
Clock
Specify a single clock frequency, in MHz. The Clock frequency defaults to different
values for the different device families (Artix-7 (including Artix-7 Automotive), Kintex-7,
and Virtex-7), but you can set the Clock frequency to any value.
• Toggle
Enter a single Toggle rate (in %). This toggle rate will apply to all the resources in the
Logic or to the BRAM.
• Enable
Enter a single Enable rate (in %). The Enable rate will apply to the slice clock enable in
the Logic or to the BRAM enable.
For more information please refer page 31 of UG440 (v2018.2).
Deepak D N
Reply or Give kudos or accept as a Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @dabangking,
Design Activity :
Clock
• Toggle
• Enable
Deepak D N
Deepak D N
dabangking
Thanks a lot!
