I can not find any information about which side is the bank belong to in UG475 (top ,bottom ,left ,right )?
where I can get that information ?
hi @microchip_zhang,
For smaller devices, it is not necessary that every bank should be present. You can verify this by selecting a device with small package(means you can see this .pkg files).
For Bank0 as tenzin told it will be in the middle of the device.
Deepak D N
Please reply or Give Kudo or Mark it as an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @microchip_zhang,
Please refer page 33 and 34 of UG475 (v1.17). which will guide you for your query.
Deepak D N
Reply or give kudo or accept as a Solution.
Deepak D N
I  have seen the figure as below,and there only left and right , what about the bank which has not been mentioned in the figure , such as bank13, bank0 , power bank ,grand bank ? and the schematic software which i am using has the blank which need to be filled
Microchip_zhang,
Assuming you are using a A50T-FGG484 by the image you attached, you do not need to to worry about bank 13 because it's not there in the A50T. Every device has bank 0 and it's usually located in the middle of the device along with the core supply voltage and ground pins. For physical pin locations of the banks which I assume you are asking for check the actual IO banking diagrams in Chapter 3. For the A50T-FFG484 see page 113 of UG475.
T
Deepak D N
Deepak D N
