I want to know the minimum Global Clock voltage to running flip flop in Spartan6.
in making a 8-bit counter using 405MHz by DCM2PLL, I want to make a clock higher than 405MHz, but higher clock is get the lower Voltage.
ex) 405MHz => 1.96 Vpp, 730MHz => 500mVpp
so, I want to know minimum voltage Global clock. Also, please write me the datasheet with the answer to the question.
Community Manager
Community Manager
Hi @tvgod2000
I'm not fully following the question here but the Spartan-6 Datasheet has sections on Switching Characteristics : https://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
That is probably what you are looking for.
Sandy
Sandy
Community Manager
Community Manager
Hi @tvgod2000
Sandy
Sandy
Thank you, I will find answer in Datasheet.
