prakashdrj
IBERT 7 series issue
Doing IBERT for 5 GT/s, with Refclk 100 MHz and data width 40 bits. I am trying to perform 2D Eye Scan for 10^-12 BER, but some how I am not able to complete the whole scan. Either hw connection lost or Progress - Incomplete occurs.
When I tried for 10^-10, 10^-11 or 10^-12 it always shows hw connection lost or Progress - Incomplete.
When I tried for 10^-9 it completes the scan.
Is there any reason for incomplete progress of scan?
Prakash
Tags (2)
kkn
can you try to reduce the cable speed and see if that helps
balkris
check this post for some suggestions on this issue
https://forums.xilinx.com/t5/Design-Tools-Others/Bug-in-Vivado-2014-1-IBERT-eye-scan-does-not-work/td-p/469038.
The reason could be cable , speed or target board hardware issue .
Thanks and Regards
Balkrishan
venkata
How does the JTAG connection exist on the hardware? Do you connect to the board through network? Doing eye scan with 10^-10, 10^-11 or 10^-12 takes fairly long time.
If you find any error message from IBERT during the failure, please provide the details.
prakashdrj
@venkata,
Sometimes progress shows incomplete or msg shown below,
Without disturbing the setup, in on going eye scan/sweep it shows this type of error.
Your help is appreciated a lot.
Prakash
balkris
the similar issue discussed in this post
https://forums.xilinx.com/t5/Design-Tools-Others/ERROR-Labtools-27-1829-vcse-server-failed-during-internal/td-p/351763
Thanks and Regards
Balkrishan
venkata
How do you connect to the hardware? Is it through network?
Can you check the Tcl console for any related messages when the error pops up?
prakashdrj
Hello @venkata,
We have connected Vivado and Zynq-ZC706 board via Cable connector J3.
prakashdrj
This type of message
"[Xicom 50-38] xicom: Core access failed. Check cable connectivity and that the target board is powered up then use the disconnect_hw_server and connect_hw_server to re-initialize the hardware target. Use open_hw_target to re-register the hardware device."
venkata
Looks like you are using digilent cable. Can you try the same test using platform usb cable?
