IBIS Simulation of XA7A50T-SG325 define-package model
I'd like to IBIS simulation of XA7A50T-CSG325.
IBIS does not make since there is no 325Pin-PKG of XA7A50T in support of the download can be device model.
Where can I get?
Re: IBIS Simulation of XA7A50T-SG325 define-package model
If the package file isn't in the download, then next best place to look is in the install directory for Vivado. For example the below is example path in my host PC - C:\Xilinx\Vivado\2015.1\data\parts\xilinx\artix7\artix7\xc7a50t\csg325.
(OR)
if you generate IBIS model in Vivado tools through your project it includes package data also.
FYI:
The below answer records are useful for you
http://www.xilinx.com/support/answers/13669.html
Also the following forum post information http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Virtex&message.id=17947 is useful
(OR)
FYI:
