08-22-2017 06:41 AM
08-22-2017 06:54 AM
Please check this thread
https://forums.xilinx.com/t5/7-Series-FPGAs/Ibis-model-for-XC7A100T-2-FGG484/m-p/766824#M21710
08-22-2017 08:20 AM - edited 08-22-2017 08:20 AM
Further,
The FGG prefix denotes the lead vs non lead material, so any F**484 package is identical (leaded vs, non-leaded does not affect the IBIS result).
08-22-2017 08:49 AM
shashank.d@siennaecad.com The downloaded folder will have the FGG484.pkg file. Include the contents of the .pkg file into the IBIS file and you will have the package details of the part.
08-23-2017 06:03 AM
Hi gnarahar,
Thanks for your reply.
I want to know how to add Package file data in IBIS file. Is there any specific format we have to follow?
08-23-2017 06:48 AM
s,
Yes. IBIS is a standard. The format must follow the standard.
08-23-2017 07:31 AM
shashank.d@siennaecad.com You need to add the .pkg details to the end of the IBIS model. Check the attached IBIS file for reference. Check from Line 5777
Make sure the correct Package is selected in the [Package] section of generic Model you downloaded. Line 33 - 39 in the attached model.
If you have the design, you can generate the design specific IBIS model using write_ibis Tcl command in Vivado. This will be much easier.
