Observer joe265
IDELAYE2 IDATAIN pin cannot be left open!!
Observing below error for AXI 1G/2.5G Ethernet Subsystem IP
[DRC REQP-83] IDATAIN_connected: block_diagram_wrapper_inst/rib_bd_i/axi_ethernet_1/U0/mac/U0/tri_mode_ethernet_mac_i/gmii_interface/delay_gmii_rx_er: For DELAY_SRC IDATAIN programming the IDATAIN input pin of IDELAYE2 must be connected.
The same project was running in vivado 14.4 where "gmii_rtl_rx_er" was set to '0'. After upgrading(to vivado 17.4) when this port is connected then the error is gone.
Have attached a screenshot of the ethernet ip configuration.
So why in vivado 17.4 the pin needs to be connected?
Tags (2)
Re: IDELAYE2 IDATAIN pin cannot be left open!!
Hi @joe265
We are talking about a very old version of Vivado as compared to an aging one.
The message is effectively saying:
You've told the IDELAY to delay an signal coming from the IO IBUF but not connected anything to it.
This won't go away.
It needs to have the GMII connected.
Keith
Hi @joe265
This won't go away.
Keith
