zaku89
IP core to be accessd by ARM and MicroBlaze
I am using ZYNQ7020 chips. We have 2 arms on PS side and 2 Microblaze on PL side.
We now want to realize the functions like:
The IP core generate some data and put it to a share memory which can be accessed by the first arm and both of the Microblaze. AXI bus solution is prefered.
Could anyone give some idea about this? Thank you!
u4223374
Advisor
Advisor
That should be fairly easy. AXI inherently supports multiple masters. Two easy options I can see:
(1) IP core has internal RAM, exposed as registers on an AXI Slave interface. Microblaze or the ARM cores can read/write those registers.
(2) IP core has an AXI Master which can then write data to a BRAM via an AXI BRAM controller, or to off-chip DDR via the Zynq HP AXI Slave ports. Microblaze and ARM can access that RAM to retrieve the results.
Xilinx provides examples of AXI Masters and AXI Slaves; have a look at those for more information.
