txjacob
ISERDES CE Clock doesn't match documentation?
I'm using the CE1 pin on an ISERDES2 block that is configured in networking mode, with 1 CE. I have the signal that is controlling CE in the CLKDIV domain, but when I implement my design I get timing issues because it says it should be in the AdcBitClk domain. This seems odd to me because when I've looked at the documentation it claims:
If CE is being driven by a signal in CLKDIV why does it complain that it is supposed to be in the AdcBitClk domain?
klumsde
Page 147-148 shows the detail of the clock enable here. It's really intended to be used as a 2:1 serial-to-parallel converter, clocked by CLKDIV.
The clock enable module is needed specifically for bidirectional memory interfaces when
ISERDESE2 is configured for 1:4 deserialization in DDR mode. When the attribute
NUM_CE = 2, the clock enable module is enabled and both CE1 and CE2 ports are
available. When NUM_CE = 1, only CE1 is available and functions as a regular clock enable.
Its the clock enable for the first rank of FFs in the iserdes so if num_ce is set to 1 by you then I could see how the tools expect it to be timed to the serial bit clock.
What is the purpose of this in your design?
txjacob
It looks like that is the problem. I missed the fact that by setting NUM_CE to 1 it was bypassing the input registers and going straight into the ISERDES registers. By setting NUM_CE to 2 and tying both to the same enable line I was able to get rid of the timing issues.
My design is intended to recieve data from an ADC. Because I need to setup the ADC before I can align the SERDES link I needed to keep it disabled until the ADC is ready to send data.
klumsde
Alternatively, you could hold the ISERDES in Reset until the ADC is ready to begin sending data.
If the deassertion of the reset is synchronous to CLKDIV then I would not forsee any issues.
Keith
