ISERDESE2 unknown outputs
I am trying to perform 1:8 deserialization on a Kintex-7 device. I am trying to simulate the deserialization, but most of the bits are just unknown at the output of the deserializer. My "vector" of outputs from the deserializer is called data_out, and only bits 6, 7, 14, 15, 22, 23, 30, 31, 38, 39 have known values. 7, 15, 23, 31, 39 are equal to INIT_Q1 (should be equal to Q1). 6, 14, 22, 30, 38 are equal to INIT_Q3 (should be equal to Q2).
I am not sure what is going on here. Any insight would be much appreciated!
Thank you,
Daniel
Code for deserializing ADC output:
// `include "timescale.v"
`timescale 1ps/1ps // this was in the SelectIO design
module LTC2195(
	input	 wire							clk_in,
	input	 wire						   rst_in,
	input  wire 			  			cmd_trig_in,
	input  wire 			  [15:0] cmd_addr_in,
	input	 wire 			  [15:0] cmd_data_in,
	output wire						 	spi_scs_out,
	output wire						 	spi_sck_out,
	output wire						 	spi_sdo_out,
	input  wire						 	spi_sdi_in,
	output wire		 					ENC_out_p,
	output wire							ENC_out_n,
	input  wire		 					DCO_in_p,
	input  wire							DCO_in_n,
	input  wire		 					FR_in_p,
	input  wire							FR_in_n,
	input  wire		 			[1:0]	D0_in_p,
	input  wire		 			[1:0]	D0_in_n,
	input  wire		 			[1:0]	D1_in_p,
	input  wire		 			[1:0]	D1_in_n,
	output reg	signed	  [15:0] ADC0_out,
	output reg	signed	  [15:0] ADC1_out,
	output reg					[7:0] FR_out
// Parameters
parameter 	SMP_DLY	= 8'h0;
parameter	CLKDIV = 8'd120; //800MHz/100 = 8Mhz, slowest ADC can go is 5MHz. CLKDIV_min = 8.
// FSM to control ENC phase shifter
reg PS_clk, PS_en, PS_inc;
wire PS_done, PS_locked;
wire [7:0] PS_status;
// State machine definitions
localparam PS_IDLE 	= 4'h0;
localparam PS_TRIG  	= 4'h1;
localparam PS_DECIDE	= 4'h2;
localparam PS_UP1A  	= 4'h3;
localparam PS_UP1B  	= 4'h4;
localparam PS_UP1C  	= 4'h5;
localparam PS_UP2  	= 4'h6;
localparam PS_UP3  	= 4'h7;
localparam PS_DOWN1A = 4'h8;
localparam PS_DOWN1B = 4'h9;
localparam PS_DOWN1C = 4'hA;
localparam PS_DOWN2  = 4'hB;
localparam PS_DOWN3  = 4'hC;
// State
// The next line makes synthesis happy
// synthesis attribute INIT of PS_state_f is "R"
reg  [3:0] PS_state_f;
reg  [8:0] PS_value_f, PS_target_f;
// State machine - combinatorial part
function [3:0] PS_next_state;
	input    [3:0] state;
	input    [8:0] value;
	input    [8:0] target;
	input				trigger;
	input	  [15:0]	address;
	input				done;
//	input				status;
	input				locked;
	begin
		case (state)
			PS_IDLE:
				if (trigger && (address[15:8] == 8'h32))
					PS_next_state = PS_TRIG;
				else
					PS_next_state = PS_IDLE;
			PS_TRIG:
					PS_next_state = PS_DECIDE;
			PS_DECIDE:
				if (locked == 1'b0)
//				else if ((target > value) && (!status || (value < 9'h100)))	//No status output available on MMCM
				else if ((target > value) && (value < 9'h100))
					PS_next_state = PS_UP1A;
//				else if ((target < value) && (!status || (value > 9'h100)))
				else if ((target < value) && (value > 9'h100))
					PS_next_state = PS_DOWN1A;
				else
			PS_UP1A:
					PS_next_state = PS_UP1B;
			PS_UP1B:
					PS_next_state = PS_UP1C;
			PS_UP1C:
					PS_next_state = PS_UP2;
			PS_UP2:
				if (done == 1'b1)
					PS_next_state = PS_UP3;
				else
			PS_UP3:
			PS_DOWN1A:
					PS_next_state = PS_DOWN1B;
			PS_DOWN1B:
					PS_next_state = PS_DOWN1C;
			PS_DOWN1C:
					PS_next_state = PS_DOWN2;
			PS_DOWN2:
				if (done == 1'b1)
					PS_next_state = PS_DOWN3;
				else
			PS_DOWN3:
			default:
		endcase
	end
endfunction
// State machine - sequential part
always @(posedge clk_in or posedge rst_in) begin
	if (rst_in) begin
		PS_state_f <= PS_DECIDE;
		PS_value_f <= 9'h100; // 256
		PS_target_f <= 9'h17C; // = decimal 380 = 256 + 124
		PS_clk <= 1'b0;
		PS_en <= 1'b0;
		PS_inc <= 1'b0;
	end
	else begin
//		PS_state_f <= PS_next_state(PS_state_f, PS_value_f, PS_target_f, cmd_trig_in, cmd_addr_in, PS_done, PS_status[0], PS_locked);
		PS_state_f <= PS_next_state(PS_state_f, PS_value_f, PS_target_f, cmd_trig_in, cmd_addr_in, PS_done, PS_locked);
		case (PS_state_f)
			PS_IDLE: begin
				PS_clk <= 1'b0;
				PS_en <= 1'b0;
				PS_inc <= 1'b0;
			end
			PS_TRIG: begin
				PS_target_f <= cmd_data_in[8:0];
			end
			PS_DECIDE: begin
			end
			PS_UP1A: begin
				PS_en <= 1'b1;
				PS_inc <= 1'b1;
			end
			PS_UP1B: begin
				PS_clk <= 1'b1;
			end
			PS_UP1C: begin
				PS_en <= 1'b0;
				PS_clk <= 1'b0;
			end
			PS_UP2: begin
				PS_clk <= ~PS_clk;
			end
			PS_UP3: begin
				PS_clk <= 1'b0;
				PS_value_f <= PS_value_f + 9'h1;
			end
			PS_DOWN1A: begin
				PS_en <= 1'b1;
				PS_inc <= 1'b0;
			end
			PS_DOWN1B: begin
				PS_clk <= 1'b1;
			end
			PS_DOWN1C: begin
				PS_en <= 1'b0;
				PS_clk <= 1'b0;
			end
			PS_DOWN2: begin
				PS_clk <= ~PS_clk;
			end
			PS_DOWN3: begin
				PS_clk <= 1'b0;
				PS_value_f <= PS_value_f - 9'h1;
			end
		endcase
	end
end
// LVDS ENC output
wire	clkPSInt, clk8xInt, clk2xInt, clkDivInt;		//clock for phase shifting of ENC, and clock for deserialization (LVDS inputs block below)
//There are no DCMs in 7 series devices. Their functionality is encompassed by PLLs and MMCMs.
//I instantiate an MMCM below.
// MMCME2_ADV: Advanced Mixed Mode Clock Manager
MMCME2_ADV #(
	.BANDWIDTH("OPTIMIZED"), 	// Jitter programming (OPTIMIZED, HIGH, LOW)
	.CLKFBOUT_MULT_F(8.0), 		// 600MHz (minimum for vco
	.CLKFBOUT_PHASE(0.0), 		// Phase offset in degrees of CLKFB (-360.000-360.000).
	// CLKIN_PERIOD: Input clock period in ns to ps resolution (i.e. 33.333 is 30 MHz).
	.CLKIN1_PERIOD(10.0),
	// CLKOUT0_DIVIDE - CLKOUT6_DIVIDE: Divide amount for CLKOUT (1-128)
	.CLKOUT1_DIVIDE(CLKDIV/8),		//8 x f_CLK0 for deserialization
	.CLKOUT2_DIVIDE(4),				//This clock for IDELAYCTRL must be 200MHz
	.CLKOUT3_DIVIDE(CLKDIV),		//Unshifted clock for deserialization
	.CLKOUT0_DIVIDE_F(CLKDIV), 	//f_CLK0 = 800MHz/CLKDIV
	// CLKOUT0_DUTY_CYCLE - CLKOUT6_DUTY_CYCLE: Duty cycle for CLKOUT outputs (0.01-0.99).
	.CLKOUT0_DUTY_CYCLE(0.5),
	.CLKOUT1_DUTY_CYCLE(0.5),
	.CLKOUT2_DUTY_CYCLE(0.5),
	.CLKOUT3_DUTY_CYCLE(0.5),
	// CLKOUT0_PHASE - CLKOUT6_PHASE: Phase offset for CLKOUT outputs (-360.000-360.000).
	.CLKOUT0_PHASE(0.0),
	.CLKOUT1_PHASE(0.0),
	.CLKOUT2_PHASE(0.0),
	.CLKOUT3_PHASE(0.0),
	.COMPENSATION("ZHOLD"), // ZHOLD, BUF_IN, EXTERNAL, INTERNAL
	.DIVCLK_DIVIDE(1), // Master division value (1-106)
	// REF_JITTER: Reference input jitter in UI (0.000-0.999).
	.REF_JITTER1(0.01),
	.STARTUP_WAIT("FALSE"), 		// Delays DONE until MMCM is locked (FALSE, TRUE)
	// USE_FINE_PS: Fine phase shift enable (TRUE/FALSE)
	.CLKFBOUT_USE_FINE_PS("FALSE"),
	.CLKOUT0_USE_FINE_PS("TRUE"),
	.CLKOUT1_USE_FINE_PS("FALSE"),
	.CLKOUT2_USE_FINE_PS("FALSE"),
	.CLKOUT3_USE_FINE_PS("FALSE")
MMCME2_ADV_inst (
	// Clock Outputs: 1-bit (each) output: User configurable clock outputs
	.CLKOUT0(clkPSInt), 				// Phase shifted clock for ENC
	.CLKOUT1(clk8xInt), 				// Deserialization clock for LVDS inputs
	.CLKOUT2(clk2xInt),				//	Clock for IDELAY control, 200MHz
	.CLKOUT3(clkDivInt),				//	Divided clock for deserialization
	// Dynamic Phase Shift Ports: 1-bit (each) output: Ports used for dynamic phase shifting of the outputs
	.PSDONE(PS_done), 				// 1-bit output: Phase shift done
	// Feedback Clocks: 1-bit (each) output: Clock feedback ports
	.CLKFBOUT(clkPSf), 				// 1-bit output: Feedback clock
	.LOCKED(PS_locked), 				// 1-bit output: LOCK
	// Clock Inputs: 1-bit (each) input: Clock inputs
	.CLKIN1(clk_in), 					// 1-bit input: Primary clock
	// Control Ports: 1-bit (each) input: MMCM control ports
	.CLKINSEL(1'b1), 					// 1-bit input: Clock select, High=CLKIN1 Low=CLKIN2
	.PWRDWN(1'b0), 					// 1-bit input: Power-down
	.RST(rst_in), 						// 1-bit input: Reset
	// DRP Ports: 7-bit (each) input: Dynamic reconfiguration ports
	.DWE(1'b0), 						// 1-bit input: DRP write enable
	// Dynamic Phase Shift Ports: 1-bit (each) input: Ports used for dynamic phase shifting of the outputs
	.PSCLK(PS_clk), 					// 1-bit input: Phase shift clock
	.PSEN(PS_en), 						// 1-bit input: Phase shift enable
	.PSINCDEC(PS_inc), 				// 1-bit input: Phase shift increment/decrement
	// Feedback Clocks: 1-bit (each) input: Clock feedback ports
	.CLKFBIN(clkPSf) 					// 1-bit input: Feedback clock
BUFG BUFG_clkPS (
	.O(clkPS), 		// 1-bit output: Clock output
	.I(clkPSInt) 	// 1-bit input: Clock input
// DDR register
wire ENC_out;
// ODDR: Output Double Data Rate Output Register with Set, Reset, and Clock Enable.
ODDR #(
	.DDR_CLK_EDGE("OPPOSITE_EDGE"), 	// "OPPOSITE_EDGE" or "SAME_EDGE"
	.INIT(1'b0), 		// Initial value of Q: 1'b0 or 1'b1
	.SRTYPE("ASYNC") 	// Set/Reset type: "SYNC" or "ASYNC"
) ODDR_inst (
	.Q(ENC_out), 	// 1-bit DDR output
	.C(clkPS), 		// 1-bit clock input
	.CE(1'b1), 		// 1-bit clock enable input
	.D1(1'b0), 		// 1-bit data input (positive edge)
	.D2(1'b1), 		// 1-bit data input (negative edge)
	.R(rst_in), 	// 1-bit reset
	.S() 				// 1-bit set
// Output buffer
OBUFDS #(
	.IOSTANDARD("LVDS_25")
obufds_inst(
	.O(ENC_out_p),
	.OB(ENC_out_n),
	.I(ENC_out)
// LVDS DCO input
// Input buffer
wire DCO_in;
// IBUFDS: Differential Input Buffer
IBUFDS #(
	.DIFF_TERM("TRUE"), 		// Differential Termination
	.IBUF_LOW_PWR("TRUE"), 	// Low power="TRUE", Highest performance="FALSE"
	.IOSTANDARD("LVDS_25") 	// Specify the input I/O standard
) IBUFDS_inst (
	.O(DCO_in), 	// Buffer output
	.I(DCO_in_p), 	// Diff_p buffer input (connect directly to top-level port)
	.IB(DCO_in_n) 	// Diff_n buffer input (connect directly to top-level port)
// LVDS inputs
localparam N_LVDS = 5;		//Number of LVDS channels
localparam N_SERIAL = 8;	//Number of bits in serial channel
wire   [N_LVDS-1:0] data_in_p, data_in_n;
assign data_in_p = {FR_in_p, D1_in_p, D0_in_p};
assign data_in_n = {FR_in_n, D1_in_n, D0_in_n};
wire [N_LVDS*N_SERIAL-1:0] data_out;
always @(posedge clk_in) begin
	//Order to get bits in right place
	ADC0_out <= {
		data_out[ 0], 	data_out[ 8], 	data_out[ 1], 	data_out[ 9], 	data_out[ 2], 	data_out[ 10], 	data_out[ 3], 	data_out[ 11],
		data_out[4], 	data_out[12], 	data_out[5], 	data_out[13], 	data_out[ 6], 	data_out[14], 		data_out[ 7], 	data_out[15]
	ADC1_out <= {
		data_out[16 + 0], data_out[16 + 8], 	data_out[16 + 1], data_out[16 + 9], 	data_out[16 + 2], data_out[16 + 10], data_out[16 + 3], data_out[16 + 11],
		data_out[16 + 4], data_out[16 + 12],	data_out[16 + 5], data_out[16 + 13],	data_out[16 + 6], data_out[16 + 14], data_out[16 + 7], data_out[16 +15]
	FR_out <= data_out[39:32];	//filling up remaining channels (extra from loop)?
end
// Generate the serial data clock - SDR at 8x the frequency of the ENC signal for a 2 wire interface
wire clk8x, clkDiv;
// Buffers for deserialization clocks.
BUFG BUFG_8x (
	.O(clk8x), 		// 1-bit output: Clock output
	.I(clk8xInt) 	// 1-bit input: Clock input
BUFG BUFG_clkDiv (
	.O(clkDiv), 	// 1-bit output: Clock output
	.I(clkDivInt) 	// 1-bit input: Clock input
// We have multiple bits - step over every bit, instantiating the required elements
wire [N_LVDS-1:0] data_in_from_pins; 			// between the input buffer and the delay
wire [N_LVDS-1:0] data_in_from_pins_delay; 	// between the delay and the deserializer
//Delay stuff unused right now
// I added 50 to all the values here because I couldn't reach the middle of the eye with the encode phase shifter (it had hit the end of its range)
//Removed the 50 to route design.
//If I want to implement delay I have to figure out IDELAYCTRL issue, and map delay values from IODELAY2 to IDELAYE2.
function integer delay_value;
	input i;
	begin
		case (i)
			0:	delay_value = 0;
			1:	delay_value = 2;
			2:	delay_value = 5;
			3:	delay_value = 8;
			4:	delay_value = 9;
			5:	delay_value = 9;
			6:	delay_value = 9;
			7:	delay_value = 8;
			8:	delay_value = 0;
			default:
				delay_value = 0;
		endcase
	end
endfunction
// Buffer for IDELAYCTRL clock.
BUFG BUFG_2x (
	.O(clk2x), 		// 1-bit output: Clock output
	.I(clk2xInt) 	// 1-bit input: Clock input
// IDELAYCTRL: IDELAYE2/ODELAYE2 Tap Delay Value Control
// Needed for IDELAYE2
(* IODELAY_GROUP = "Input_Delay" *) // Specifies group name for associated IDELAYs/ODELAYs and IDELAYCTRL
IDELAYCTRL IDELAYCTRL_inst (
	.RDY(), 				// 1-bit output: Ready output
	.REFCLK(clk2x), 	// 1-bit input: Reference clock input
	.RST(rst_in) 		// 1-bit input: Active high reset input
genvar pin_count;
generate for (pin_count = 0; pin_count < N_LVDS; pin_count = pin_count + 1) begin: pins
	IBUFDS #(
		.IBUF_LOW_PWR("FALSE"), 	// Low power="TRUE", Highest performance="FALSE"
	) IBUFDS_inst (
		.O(data_in_from_pins[pin_count]), 	// Buffer output
		.I(data_in_p[pin_count]), 				// Diff_p buffer input (connect directly to top-level port)
		.IB(data_in_n[pin_count]) 				// Diff_n buffer input (connect directly to top-level port)
	// IDELAYE2: Input Fixed or Variable Delay Element
	IDELAYE2 #(
		.CINVCTRL_SEL("FALSE"), 					// Enable dynamic clock inversion (FALSE, TRUE)
		.DELAY_SRC("IDATAIN"), 						// Delay input (IDATAIN, DATAIN)
		.HIGH_PERFORMANCE_MODE("TRUE"), 			// Reduced jitter ("TRUE"), Reduced power ("FALSE")
		.IDELAY_TYPE("FIXED"), 						// FIXED, VARIABLE, VAR_LOAD, VAR_LOAD_PIPE
		.IDELAY_VALUE(delay_value(pin_count)),	// Input delay tap setting (0-31)
		.PIPE_SEL("FALSE"), 							// Select pipelined mode, FALSE, TRUE
		.REFCLK_FREQUENCY(200.0), 					// IDELAYCTRL clock input frequency in MHz (190.0-210.0, 290.0-310.0).
		.SIGNAL_PATTERN("DATA") 					// DATA, CLOCK input signal
	IDELAYE2_inst (
		.IDATAIN(data_in_from_pins[pin_count]), 			// 1-bit input: Data input from the I/O
		.DATAOUT(data_in_from_pins_delay[pin_count]), 	// 1-bit output: Delayed data output
		.C(1'b0), 													// 1-bit input: Clock input
		.CE(1'b0), 												// 1-bit input: Active high enable increment/decrement input
		.CINVCTRL(), 												// 1-bit input: Dynamic clock inversion input
		.CNTVALUEIN(), 											// 5-bit input: Counter value input
		.DATAIN(), 													// 1-bit input: Internal delay data input
		.INC(),	 													// 1-bit input: Increment / Decrement tap delay input
		.LD(), 														// 1-bit input: Load IDELAY_VALUE input
		.LDPIPEEN(1'b0),		 									// 1-bit input: Enable PIPELINE register to load data input
		.REGRST(1'b0),	 											// 1-bit input: Active-high reset tap-delay input
		.CNTVALUEOUT()												// 5-bit output: Counter value output
	 // ISERDESE2: Input SERial/DESerializer with Bitslip
ISERDESE2 #(
.DATA_RATE("SDR"), // DDR, SDR
.DATA_WIDTH(8), // Parallel data width (2-8,10,14)
.DYN_CLKDIV_INV_EN("FALSE"), // Enable DYNCLKDIVINVSEL inversion (FALSE, TRUE)
.DYN_CLK_INV_EN("FALSE"), // Enable DYNCLKINVSEL inversion (FALSE, TRUE)
// INIT_Q1 - INIT_Q4: Initial value on the Q outputs (0/1)
.INIT_Q1(1'b0),
.INIT_Q2(1'b0),
.INIT_Q3(1'b0),
.INIT_Q4(1'b0),
.INTERFACE_TYPE("NETWORKING"), // MEMORY, MEMORY_DDR3, MEMORY_QDR, NETWORKING, OVERSAMPLE
.IOBDELAY("NONE"), // NONE, BOTH, IBUF, IFD
.NUM_CE(2), // Number of clock enables (1,2)
.OFB_USED("FALSE"), // Select OFB path (FALSE, TRUE)
.SERDES_MODE("MASTER"), // MASTER, SLAVE
// SRVAL_Q1 - SRVAL_Q4: Q output values when SR is used (0/1)
.SRVAL_Q1(1'b0),
.SRVAL_Q2(1'b0),
.SRVAL_Q3(1'b0),
.SRVAL_Q4(1'b0)
ISERDESE2_inst (
.O(), // 1-bit output: Combinatorial output
// Q1 - Q8: 1-bit (each) output: Registered data outputs
.Q1(data_out[N_SERIAL*pin_count+7]),
.Q2(data_out[N_SERIAL*pin_count+6]),
.Q3(data_out[N_SERIAL*pin_count+5]),
.Q4(data_out[N_SERIAL*pin_count+4]),
.Q5(data_out[N_SERIAL*pin_count+3]),
.Q6(data_out[N_SERIAL*pin_count+2]),
.Q7(data_out[N_SERIAL*pin_count+1]),
.Q8(data_out[N_SERIAL*pin_count+0]),
// SHIFTOUT1, SHIFTOUT2: 1-bit (each) output: Data width expansion output ports
.SHIFTOUT1(),
.SHIFTOUT2(),
.BITSLIP(), // 1-bit input: The BITSLIP pin performs a Bitslip operation synchronous to
// CLKDIV when asserted (active High). Subsequently, the data seen on the Q1
// to Q8 output ports will shift, as in a barrel-shifter operation, one
// position every time Bitslip is invoked (DDR operation is different from
// SDR).
// CE1, CE2: 1-bit (each) input: Data register clock enable inputs
.CE1(1'b1),
.CE2(1'b1),
.CLKDIVP(1'b0), // 1-bit input: TBD
// Clocks: 1-bit (each) input: ISERDESE2 clock input ports
.CLK(CLK), // 1-bit input: High-speed clock
.CLKB(clk8x), // 1-bit input: High-speed secondary clock
.CLKDIV(clkDiv), // 1-bit input: Divided clock
.OCLK(1'b0), // 1-bit input: High speed output clock used when INTERFACE_TYPE="MEMORY"
// Dynamic Clock Inversions: 1-bit (each) input: Dynamic clock inversion pins to switch clock polarity
.DYNCLKDIVSEL(), // 1-bit input: Dynamic CLKDIV inversion
.DYNCLKSEL(), // 1-bit input: Dynamic CLK/CLKB inversion
// Input Data: 1-bit (each) input: ISERDESE2 data input ports
.D(data_in_from_pins[pin_count]), // 1-bit input: Data input
.DDLY(), // 1-bit input: Serial data from IDELAYE2
.OFB(), // 1-bit input: Data feedback from OSERDESE2
.OCLKB(), // 1-bit input: High speed negative edge output clock
.RST(rst_in), // 1-bit input: Active high asynchronous reset
// SHIFTIN1, SHIFTIN2: 1-bit (each) input: Data width expansion input ports
.SHIFTIN1(1'b0),
.SHIFTIN2(1'b0)
); end endgenerate
Here's my testbench:
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:   13:38:51 06/08/2017
// Design Name:   LTC2195
// Module Name:   C:/Users/dschussheim/Documents/GitHub/digital-servo/firmware/LTC2195_tb.v
// Project Name:  SuperLaserLand
// Target Device:
// Tool versions:
// Description:
// Verilog Test Fixture created by ISE for module: LTC2195
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module LTC2195_tb;
	// Inputs
	reg clk_in;
	reg rst_in;
	reg cmd_trig_in;
	reg [15:0] cmd_addr_in;
	reg [15:0] cmd_data_in;
	reg spi_sdi_in;
	reg DCO_in_p;
	reg DCO_in_n;
	reg FR_in_p;
	reg FR_in_n;
	reg [1:0] D0_in_p;
	reg [1:0] D0_in_n;
	reg [1:0] D1_in_p;
	reg [1:0] D1_in_n;
	// Outputs
	wire spi_scs_out;
	wire spi_sck_out;
	wire spi_sdo_out;
	wire ENC_out_p;
	wire ENC_out_n;
	wire [15:0] ADC0_out;
	wire [15:0] ADC1_out;
	wire [7:0] FR_out;
	// Instantiate the Unit Under Test (UUT)
	LTC2195 uut (
		.clk_in(clk_in),
		.rst_in(rst_in),
		.cmd_trig_in(cmd_trig_in),
		.cmd_addr_in(cmd_addr_in),
		.cmd_data_in(cmd_data_in),
		.spi_scs_out(spi_scs_out),
		.spi_sck_out(spi_sck_out),
		.spi_sdo_out(spi_sdo_out),
		.spi_sdi_in(spi_sdi_in),
		.ENC_out_p(ENC_out_p),
		.ENC_out_n(ENC_out_n),
		.DCO_in_p(DCO_in_p),
		.DCO_in_n(DCO_in_n),
		.FR_in_p(FR_in_p),
		.FR_in_n(FR_in_n),
		.D0_in_p(D0_in_p),
		.D0_in_n(D0_in_n),
		.D1_in_p(D1_in_p),
		.D1_in_n(D1_in_n),
		.ADC0_out(ADC0_out),
		.ADC1_out(ADC1_out),
		.FR_out(FR_out)
	initial begin
		// Initialize Inputs
		clk_in = 0;
		rst_in = 0;
		cmd_trig_in = 0;
		cmd_addr_in = 0;
		cmd_data_in = 0;
		spi_sdi_in = 0;
		DCO_in_p = 0;
		DCO_in_n = ~DCO_in_p;
		FR_in_p = 0;
		FR_in_n = ~FR_in_p;
		D0_in_p = 2'b11;
		D0_in_n = ~D0_in_p;
		D1_in_p = 2'b00;
		D1_in_n = ~D1_in_p;
		// Add stimulus here
		#500	rst_in = 1;
		#100	rst_in = 0; //DCM SP says reset must be high for at least 3 valid clock cycles
	end
	//Clock
	always
		#5 clk_in = ~clk_in;  // 100 MHz
	always
		#1.25	DCO_in_p = ~DCO_in_p;
	always
		#1.25	DCO_in_n = ~DCO_in_n;
	always
		#5	FR_in_p = ~FR_in_p;
	always
		#5	FR_in_n = ~FR_in_n;
endmodule
Re: ISERDESE2 unknown outputs
Simulation works fine in Vivado 2017.2.
I guess there is a bug in the simulation compiler for ISE!
Teacher muzaffer
@dschussheim connect floating inputs to iserdes (specifically bitslip to zero) and see if that makes a difference.
@muzaffer Thanks for your reply. Tying unused inputs to ground didn't change anything on the output....
I put together a simpler module that only has the deserializer (for readability). Q = xxxxxx00 for the code below. In general, Q[0] = INIT_Q1, Q[1] = INIT_Q3.
module deserializer(
    output [7:0] Q,
    input D,
    input clk,
    input clkDiv,
    input rst
parameter DATA_WIDTH = 8;
ISERDESE2 #(
	.DATA_WIDTH(DATA_WIDTH), 			// Parallel data width (2-8,10,14)
	.INIT_Q1(1'b0),
	.INIT_Q2(1'b0),
	.INIT_Q3(1'b0),
	.INIT_Q4(1'b0),
	.SRVAL_Q1(1'b0),
	.SRVAL_Q2(1'b0),
	.SRVAL_Q3(1'b0),
	.SRVAL_Q4(1'b0)
ISERDESE2_inst (
	.Q1(Q[0]),
	.Q2(Q[1]),
	.Q3(Q[2]),
	.Q4(Q[3]),
	.Q5(Q[4]),
	.Q6(Q[5]),
	.Q7(Q[6]),
	.Q8(Q[7]),
	.SHIFTOUT1(),
	.SHIFTOUT2(),
	.BITSLIP(1'b0), 		// 1-bit input: The BITSLIP pin performs a Bitslip operation synchronous to
	// SDR).
	.CE1(1'b1),
	.CE2(1'b1),
	.CLK(clk), 			// 1-bit input: High-speed clock
	.CLKB(1'b0), 			// 1-bit input: High-speed secondary clock
	.DYNCLKDIVSEL(1'b0),	// 1-bit input: Dynamic CLKDIV inversion
	.DYNCLKSEL(1'b0), 		// 1-bit input: Dynamic CLK/CLKB inversion
	.D(D), 				// 1-bit input: Data input
	.DDLY(1'b0), 			// 1-bit input: Serial data from IDELAYE2
	.OFB(1'b0), 				// 1-bit input: Data feedback from OSERDESE2
	.OCLKB(1'b0), 			// 1-bit input: High speed negative edge output clock
	.RST(rst), 		// 1-bit input: Active high asynchronous reset
	.SHIFTIN1(1'b0),
	.SHIFTIN2(1'b0)
endmodule
Testbench
module deserializer_tb;
	// Inputs
	reg D;
	reg clk;
	reg clkDiv;
	reg rst;
	// Outputs
	wire [7:0] Q;
	deserializer uut (
		.Q(Q),
		.D(D),
		.clk(clk),
		.clkDiv(clkDiv)
	initial begin
		D = 0;
		clk = 0;
		clkDiv = 0;
		rst = 0;
		// Wait 100 ns for global reset to finish
		#300;
       rst = 1;
		 #500 rst = 0;
	end
	always
		#10 clk = ~clk;
	always
		#80 clkDiv = ~clkDiv;
endmodule
One thing I noticed is that the rst input does not change the output of ISERDESE2 at all.
Teacher muzaffer
@dschussheim try
	.CLKB(!clk), 			// 1-bit input: High-speed secondary clock
@muzaffer My CLK/CLKDIV inputs were not aligned properly in simulation. Now they are aligned. I get all xxxx at outputs regardless of inputs. CLKB being grounded or inverted version of CLK does not change outputs.
I tried BUFIO(.I(clk),.o(clk_in)) --> .CLK(clk_in), and BUFR(.I(clk),.O(.clkDiv_in)) (divide by 8) --> .CLKDIV(clkDiv_in), and .CLKB(!clk_in).
With the buffered clk inputs I get similar behavior to before, where Q1 and Q2 are determined by INIT_Q1 and INIT_Q3, but now if either of those initial values are 1, I get an x.
Just for reference I am using ISE webpack 14.7/iSim 14.7
	output	wire	[3:0]	Q,
    input 	wire			D,
    input 	wire			clk,
    input 	wire			clkDiv,
	 input 	wire			rst
parameter DATA_WIDTH = 4;
// BUFIO: Local Clock Buffer for I/O
BUFIO BUFIO_inst (
	.O(clk_in), // 1-bit output: Clock output (connect to I/O clock loads).
	.I(clk) // 1-bit input: Clock input (connect to an IBUF or BUFMR).
// BUFR: Regional Clock Buffer for I/O and Logic Resources within a Clock Region
// 7 Series
// Xilinx HDL Libraries Guide, version 14.7
BUFR #(
	.BUFR_DIVIDE("4"), // Values: "BYPASS, 1, 2, 3, 4, 5, 6, 7, 8"
	.SIM_DEVICE("7SERIES") // Must be set to "7SERIES"
BUFR_inst (
	.O(clkDiv_in), // 1-bit output: Clock output port
	.CE(1'b1), // 1-bit input: Active high, clock enable (Divided modes only)
	.CLR(rst), // 1-bit input: Active high, asynchronous clear (Divided modes only)
	.I(clk) // 1-bit input: Clock buffer input driven by an IBUF, MMCM or local interconnect
ISERDESE2 #(
	.INIT_Q1(1'b0),
	.INIT_Q2(1'b1),
	.INIT_Q3(1'b0),
	.INIT_Q4(1'b0),
	.NUM_CE(1), 							// Number of clock enables (1,2)
	.SRVAL_Q1(1'b0),
	.SRVAL_Q2(1'b0),
	.SRVAL_Q3(1'b0),
	.SRVAL_Q4(1'b0)
ISERDESE2_inst (
	.Q1(Q[0]),
	.Q2(Q[1]),
	.Q3(Q[2]),
	.Q4(Q[3]),
	.Q5(),
	.Q6(),
	.Q7(),
	.Q8(),
	.SHIFTOUT1(),
	.SHIFTOUT2(),
	// SDR).
	.CE1(1'b1),
	.CE2(1'b0),
	.CLK(clk_in), 			// 1-bit input: High-speed clock
	.CLKB(!clk_in), 			// 1-bit input: High-speed secondary clock
	.CLKDIV(clkDiv_in), 	// 1-bit input: Divided clock
	.SHIFTIN1(1'b0),
	.SHIFTIN2(1'b0)
endmodule
I think this may be a simulation issue. When I switch to "OVERSAMPLE" mode, and give the proper clocks as per UG471, ISERDESE2 simulates fine. The problem is, I need 1:8 deserialization, and only "NETWORKING" supports this data width.
Has anyone else used NETWORKING mode on ISERDESE2, or know anything useful about it? It should not be this complicated to use a deserializer....
Community Manager
Community Manager
Networking would be the most popular mode for the ISERDES (outside MIG of course). Might be worth looking at an Xapp like Xapp1017 :https://www.xilinx.com/support/documentation/application_notes/xapp1017-lvds-ddr-deserial.pdf
It has an example design with a test bench.
Sandy
