Instantiation in Verilog (Test bench file) for a block design - Vivado
Where is the instantiation list of the block?
It is not working with the list I found in design_1.bd under "components"
I suppose it is not possible to instantiate the blocks?
so here the alternative I found doing it in html/ javascript,
here some code I use hope it helps (I included something to convert decimals and binaries or to do some padding:
just copy whats from <html> to </html> into a notepad and save as test.html or any other name and open it in a browser
<!DOCTYPE html>
<html>
<body>
<p id="demo"></p>
<script>
var etad = new Date();
var i;
var text = "`timescale 1ns / 1ps<br>";
text += "// " + etad + " <br>";
text += "//  Comments <br>";
for (i = 0; i < 20; i += 1) {
text += "wire [7:0] D"+i+";"+ " <br>";
text += "assign D"+i+"[7:0] = ledx["+(7+i*8)+":"+(i*8)+"];"+ " <br>";
text += "assign swx["+(7+i*8)+":"+(i*8)+"] = DB[7:0];"+ " <br>"; }
text += "module test( swx, ledx); <br><br>";
text += "input [7:0] swx; <br>";
text += "output [7:0] ledx;<br>";
text += "endmodule ";
document.getElementById("demo").innerHTML = text;
function dec2bin(dec) {
return dec.toString(2);
function padDigits(number, digits) {
return Array(Math.max(digits - String(dec2bin(number)).length + 1, 0)).join(0) + dec2bin(number);
/*function exportToCsv() {
var myCsv = "Col1,Col2,Col3\nval1,val2,val3";
window.open('data&colon;text/csv;charset=utf-8,' + escape(myCsv));
var button = document.getElementById('b');
button.addEventListener('click', exportToCsv);
</script>
</body>
</html>
1. I right clicked the block and chosed create hierarchy to push it one deeper
2. I ctrl click the design blocks that have Input/Outputs
3. I select the "Make External" so it wired the pins to the top layer
4. I wait 10-30 min for Vivado to write the files
5. open \project_1\project_1.srcs\sources_1\bd\design_1\design_1.bd
    That file gives the instantiation list "component ..."
I am now trying to instanciate the block for a verilog file I am writing as test bench
where is the the instatiation for the block from the block design, I want to write a verilog test bench
Can I converty a block into verilog (like was possible for ISE)?
<!DOCTYPE html>
<html>
<body>
<p id="demo"></p>
<script>
var i;
</script>
</body>
</html>
Note :
Edge IE and Chrome fail to let a copy paste for very large files but Mozilla Firefox managed fine.
That is what I found out after 3 hours trying to wait for Edge to crash and chrome none better.
Firefox worked and I was glad it installed also within seconds, sorry to mention this but Edge and Chrome fail so if anyone is using javascript for the very large netlists like I mentionned please use Firefox
please anyone give me Kudos I really spend lots of time to find all that out and share and deserve a bit of "kuddos-love"..
