Integrating Microblaze to System Generator
Hi ,
I am working on Kintex 7 Board. My design approach is to first place my design in System generator and generate the RTL code and integrate.
With this, i am running out of resources.
SO, i want to use Microblaze for some of the operations ( sothat load is shared between FPGA and microblaze).
I am trying to see is there a way i can integrate Microblaze to System generator?
I am planning for C Code to be placed in Microblaze.
When i looked at user guide for DSP from the below link, i could see like it is possible to integrate microblaze.
www.xilinx.com/support/sw_manuals/sysgen_gs.pdf
Please find some of the lines from the above document saying MB can be included in SysGen.
“System Generator also supports the inclusion of a MicroBlaze embedded processor running C/C++ programs.”
“Demonstrates how to import a MicroBlaze processor created using Xilinx Platform Studio into System Generator. A DSP48 block is used as a co-processor to the MicroBlaze.”
So, Please confirm/ provide data for the below queries.
  1. Can i integrate Microblaze to System generator?
  2. If yes, Can i write C Code and integrate?
  3. Can you share the link where i could see the demo/example project where microblaze is integrated to sysGen?
Quick response is hightly appreciated. Please help.
Regardss,
Keshav
Re: Integrating Microblaze to System Generator
Please note that we are working on Vivado Design Suite
