09-01-2017 02:58 AM
09-01-2017 03:08 AM
Hey @yogesh_tripathi,
There is always a possibility ...
As you already stated, HDMI will require at least three of the four tranceiver which leaves you with a single tranceiver for PCIe. So far so good, but you need to address the HDMI clock (you can probably use a normal I/O for that) and utilize both MGT clocks in the quad with different settings for HDMI and PCIe. I'm pretty sure there is no reference design or official support for this though.
Hope this helps,
Herbert
09-01-2017 03:48 AM
Hi Herbert,
Thank-you for the quick reply.
Hope it works. One more doubt, Why GT wizard is showing only using one gtp_channel as shown in image below instead of three.
09-01-2017 04:01 AM
I'd say because you are only configuring one of the three (or four) channels ...
Best,
Herbert
