Is the virtex 5 will be discountinued the next few years
we have a project using the virtex 5 FPGAs.Is't will be discountinued the next few years?
Which  year is the V5 FPGA In production?
TKS!
When a chip came out is no indication on how long it has to last,
Also , different packages of a certain chip will have different lifes to others,
You also need to take int account things like government, e.g. a lot of good parts went EOL when the ROHS constraints came in, acts of god as in plant being destroyed by tsunamie, et all.
In hindsight, Its amazing that these things have as long a life as they do
Bottom line, Talk to your FAE is the best bet, and they will give you what they can
hi @wq174186,
Thanks for contacting Xilinx technical forums on the query viterx -5 FPGA life span.
Currently virtex-5 are in saturation stage of life cycle ,to more about this device viability you can cross with local FAE and sale team
https://www.xilinx.com/about/contact/sales-reps.html
https://www.xilinx.com/about/contact/locations.html?categoryPreSelect=Authorized%20Distributors
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
