arevhamb
KC705 ddr2 support
Does anybody have experience in supporting DDR2 with SO-DIMM socket on KC705 evaluation board.
DDR2 requires power supply to be 1.8V. I have tried to increase power supply voltage (which is 1,5V by default for the support of DDR3) to be 1.8V, programming power controller from TI, responsible for formation of power rails, but the highest value I was able to get was 1.6V.
I am using TI USB-to-GPIO adapter, and TI Fusion Power Designer software, to program the voltage levels.
Thank you in advance,
Arevik
jheslip
I am not aware of anyone doing DDR2 on the KC705. the only way to adjust the rails is with the TI cable so if that is limiting to 1.6v then that's the max. What is the VIH MIN for the DDR2 module you want to use? if t is less than 1.6V then it could work.
balkris
No DDR2 not supported for KC705 board
Thanks and Regards
Balkrishan
arevhamb
Thank you for your answers.
I guess the problem is in the power controller, which checks for the output voltage to be in some limits.
Is there a way to increase the limits, so that it will be possible to have voltage higher than 1.6V? I checked the schematics fro the KC705 board, and seems, the VCC1V5_FPGA power rail is used only for the Banks 32, 33, 34 and LCD, so it should not damage any internal circuits.
Arevik
jheslip
There is no supported way that I am aware of. You could rework the board for this test and supply your own 1.8V from a bench supply.
