07-19-2018 10:06 AM
Reference: custom RTL module on Genesys 2 board (XCK325T)
I have defined constraints in the xdc file for external differential clock input namely CLK_FPGA_SYNTH_N , and CLK_FPGA_SYNTH_P, which is connected via MRCC pins (D13 and D12) in bank-18. This bank is connected with VCCO=1.8V and all other lines in this bank are set with IOSTANDARD LVCMOS18.
The definition for CLK_FPGA_SYNTH_N and CLK_FPGA_SYNTH_P in xdc file is as follows:
set_property -dict { PACKAGE_PIN D13 IOSTANDARD LVDS } [get_ports { CLK_FPGA_SYNTH_N }];
set_property -dict { PACKAGE_PIN D12 IOSTANDARD LVDS } [get_ports { CLK_FPGA_SYNTH_P }];
However DRC error is detected during 'place design':
[DRC BIVB-1] Bank IO standard Support: Bank 18 has incompatible IO(s) because: The LVDS I/O standard is not supported. Move the following ports or change their properties:
CLK_FPGA_SYNTH_P
How to resolve this error?
Thanks and
Best Regards
--Subhash
07-19-2018 02:31 PM - edited 07-19-2018 02:33 PM
Subhashkrishnan,
Well you see LVDS is available for only HP banks and you are using bank 18 which is an HR bank. So you should use LVDS_25. Just make sure that DIFF_TERM isn't used for termination. Either external differential termination should be used or you should just use DIFF_SSTL/HSTL variant with IN_TERM if you HAVE to use internal termination.
T
Subhashkrishnan,
T
07-19-2018 09:16 PM
Thank you. I had corrected this till bank-17, but somehow overlooked.
Thanks for support
Best Regards
--Subhash
