cowiebm
Kintex7 configuration
Can I use a platform flash device (xcf128) to configure the Kintex7 using Selectmap mode? The configuration guide suggests using a microprocessor or a CPLD between the Kintex7 and the memory device(s) but is this really necessary or can I just use an xcf128 device as I used to with spartan6 and Virtex FPGAs?
randal
The XCF128X is not supported with the 7 series.
smarell
Community Manager
Community Manager
The XCF128X flash is supported only with Virtex-5 or Virtex-6 devices and it si one of the unsupported flashes for 7-series.
