LVCMOS18_XX IO Standards and usage
In Virtex-7 FPGA I am evaluating using a 312.5M (3.2 ns) output through LVCMOS18 IO to an external PHY board. While looking through the datasheet for switching characteristics I see the following different standards within LVCMOS18. What do they mean? And how do I know which one is used/ how to force one of the standards?
LVCMOS18 - different typesLVCMOS18 - different types
set_property IOSTANDARD LVCMOS18 [get_ports {us_TxData[0]}] is the constrain I use. The FPGA I am evaluating is: xc7v585tffg1761-2
Please can someone help with this as soon as possible as I am trying to meet a deadline.
Thank you very much!
Sundar
Tags (3)
Re: LVCMOS18_XX IO Standards and usage
Hi @sundarbas
It specifies the Slew rate and drive strength. Please check the below section in 7 series selectIO user guide
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
