Observer luganliuxi321
LVDS_33 on HR bank?
   My  FPGA is XC7K325T-1FFG900I.  About LVDS signals , It seems that there is only LVDS_25. Is it right?
   If i set the HR bank 3.3V, the output pins of the  bank can not output LVDS, Is it right?
Re: LVDS_33 on HR bank?
That is correct.  The VCCO of the HR banks for LVDS outputs (and inputs with DIFF_TERM) must be 2.5V.  The XC7K325T also has HP banks where the LVDS outputs (and inputs with DIFF_TERM) must be 1.8V.
But in this post,it says It is acceptable to have LVDS inputs in HP I/O banks even if the VCCO level is not 1.8V.
Similarly, it is acceptable to have LVDS_25 inputs in HR I/O banks even if the VCCO level is not 2.5V.
http://www.xilinx.com/support/answers/43989.html
Yes, the steps mentioned in AR can be a workaround to use LVDS variants in HP/HR  Banks
Vanitha
Got it ,thanks!
Newbie rohitcif
HR bank voltage range is 1.8 to 3.3 volt and HP bank voltage range is 1.2 to 1.8 volt , no according to voltage you can select bank.
