xxy012600
LogiCORE DisplayPort Receiver v7.0 (Rev. 1) - XAPP1178 - XAPP1271 - Why does the DisplayPort RX driver for the DisplayPort IP fail to train when using windows xp?
DisplayPort IP fail to train when using windows XP on computer?the computer can not output 4K resolution.
But that is Successful to train when windows 7 on computer,the computer can output 4K resolution.
vijayak
Hi @xxy012600
This looks to be related to usage of unsupported OS and using the supported OS is giving you the intended results.
These Xapps are tested with Vivado 2016.1 and attaching the list of supported OS with 2016.1 for your reference.
Thanks,Vijay
xxy012600
thank you!But I want to ask Whether the DisplayPort IP support to train to the computer when the computer is using windows XP or not,rather than Microsoft Windows support.
