amol.ghaware
MCS file program faild artix7 FPGA
Dear all,
  I am getting the following error while loading the MCS file through IMPACT
Creating backup of last automatically saved project to 'C:\Xilinx\\auto_project_1.ipf'.
Welcome to iMPACT
iMPACT Version: 14.7
Project: 'C:\Xilinx\\auto_project.ipf' already exists.
Original project has been renamed to 'C:\Xilinx\\auto_project_1.ipf'.
Project: C:\Xilinx\\auto_project.ipf created.
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: found 1 device(s).
INFO:iMPACT - Digilent Plugin: opening device: "JtagHs2", SN:210249937944
INFO:iMPACT - Digilent Plugin: User Name: JtagHs2
INFO:iMPACT - Digilent Plugin: Product Name: Digilent JTAG-HS2
INFO:iMPACT - Digilent Plugin: Serial Number: 210249937944
INFO:iMPACT - Digilent Plugin: Product ID: 30900152
INFO:iMPACT - Digilent Plugin: Firmware Version: 0108
INFO:iMPACT - Digilent Plugin: JTAG Port Number: 0
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 10000000 Hz
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 1/24/2015 12:37:15 PM
// *** BATCH CMD : Identify -inferir
Identifying chain contents...'0': : Manufacturer's ID = Xilinx XC7A200T, Version : 1
INFO:iMPACT:1777 -
Reading C:/Xilinx14.7/14.7/LabTools/LabTools/artix7/data/xc7a200t.bsd...
INFO:iMPACT - Using CseAdapterBSDevice
INFO:iMPACT:501 - '1': Added Device XC7A200T successfully.
done.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
// *** BATCH CMD : identifyMPM
INFO:iMPACT - Current time: 1/24/2015 12:37:23 PM
// *** BATCH CMD : ReadStatusRegister -p 1
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   32.66 C, Min. Reading:   32.16 C, Max. Reading:   33.15 C
1: VCCINT Supply: Current Reading:   0.999 V, Min. Reading:   0.996 V, Max. Reading:   0.999 V
1: VCCAUX Supply: Current Reading:   1.828 V, Min. Reading:   1.825 V, Max. Reading:   1.831 V
'1': Reading bootsts register contents...
[0] VALID_0 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[1] FALLBACK_0 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[2] IPROG_0 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION          :         0
[3] WTO_ERROR_0 - WATCHDOG TIME OUT ERROR                                  :         0
[4] ID_ERROR_0 - FPGA DEVICE IDCODE ERROR                                  :         0
[5] CRC_ERROR_0 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                      :         0
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR             :         0
[7] HMAC_ERROR_0 - HMAC ERROR                                              :         0
[8] VALID_1 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[9] FALLBACK_1 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[10] IPROG_1 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION         :         0
[11] WTO_ERROR_1 - WATCHDOG TIME OUT ERROR                                 :         0
[12] ID_ERROR_1 - FPGA DEVICE IDCODE ERROR                                 :         0
[13] CRC_ERROR_1 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                     :         0
[14] WRAP_ERROR_1 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR            :         0
[15] HMAC_ERROR_1 - HMAC ERROR                                             :         0
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] DECRYPTOR ENABLE                                                       :         0
[2] PLL LOCK STATUS                                                        :         1
[3] DCI MATCH STATUS                                                       :         1
[4] END OF STARTUP (EOS) STATUS                                            :         0
[5] GTS_CFG_B STATUS                                                       :         0
[6] GWE STATUS                                                             :         0
[7] GHIGH STATUS                                                           :         0
[8] MODE PIN M[0]                                                          :         1
[9] MODE PIN M[1]                                                          :         0
[10] MODE PIN M[2]                                                         :         0
[11] INIT_B INTERNAL SIGNAL STATUS                                         :         1
[12] INIT_B PIN                                                            :         1
[13] DONE INTERNAL SIGNAL STATUS                                           :         0
[14] DONE PIN                                                              :         0
[15] IDCODE ERROR                                                          :         0
[16] SECURITY ERROR                                                        :         0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS                                 :         0
[18] CFG STARTUP STATE MACHINE PHASE                                       :         0
[19] CFG STARTUP STATE MACHINE PHASE                                       :         0
[20] CFG STARTUP STATE MACHINE PHASE                                       :         0
[21] RESERVED                                                              :         0
[22] RESERVED                                                              :         0
[23] RESERVED                                                              :         0
[24] RESERVED                                                              :         0
[25] CFG BUS WIDTH DETECTION                                               :         0
[26] CFG BUS WIDTH DETECTION                                               :         0
[27] HMAC ERROR                                                            :         0
[28] PUDC_B PIN                                                            :         1
[29] BAD PACKET ERROR                                                      :         0
[30] CFGBVS PIN                                                            :         1
[31] RESERVED                                                              :         0
IDCODE Loop Count = 10000
INFO:iMPACT - Current time: 1/24/2015 12:37:27 PM
// *** BATCH CMD : ReadIdcode -loop 10000 -p 1
Validating chain...
1: Device Temperature: Current Reading:   33.15 C, Min. Reading:   32.16 C, Max. Reading:   33.15 C
'1': IDCODE loop completed successfully 10000 times.
Elapsed time =      3 sec.
IDCODE Loop Count = 100000
INFO:iMPACT - Current time: 1/24/2015 12:37:37 PM
// *** BATCH CMD : ReadIdcode -loop 100000 -p 1
Validating chain...
1: Device Temperature: Current Reading:   33.15 C, Min. Reading:   32.16 C, Max. Reading:   33.64 C
'1': IDCODE loop completed successfully 100000 times.
Elapsed time =     24 sec.
INFO:iMPACT - File C:/Documents and Settings/itsadmin.ITT039/Desktop/0169/DP-SPL-0169-V1-01-U408-R1-0037C42A9.cfi does not exist.
Selected part: S25FL256S
// *** BATCH CMD : attachflash -position 1 -spi "S25FL256S"
Unprotect sectors: FALSE
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "C:/Documents and Settings/itsadmin.ITT039/Desktop/0169/DP-SPL-0169-V1-01-U408-R1-0037C42A9.mcs"
INFO:iMPACT - A CFI file is not detected. To ensure correct and safe configuration,
 Please make sure a CFI file is present in the same directory as the PROM file,
 or, regenerate the PROM file with the latest software.
Enumerating cables. Please wait.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Source driver files not found.
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
the Cable Setup operation.
// *** BATCH CMD : setCable -target "digilent_plugin DEVICE=SN:210249937944 FREQUENCY=1000000"
INFO:iMPACT - Digilent Plugin: Opening device : "SN:210249937944".
INFO:iMPACT - Digilent Plugin: JTAG Clock Frequency: 1000000 Hz
INFO:iMPACT - Current time: 1/24/2015 12:41:59 PM
// *** BATCH CMD : Program -p 1 -dataWidth 4 -spionly -e -v -loadfpga
Validating chain...
SPI SLAVE TYPE in Cse_Operate.c is 0
INFO:iMPACT - Downloading C:\Xilinx14.7\14.7\LabTools\LabTools\data\cse\cseflash\artix7\xc7a200t_xsdbspi.cor core file.
INFO:iMPACT - Creating XC7A200T device.
'1': Programming device...
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 1001 1110 0000 1000 0000 0010
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
Elapsed time =     10 sec.
key: period_frc, value: 0
key: dclk_has_reset, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
Slave Int Type is 99, slave Index is 0 , SPI_SLAVE is 99
Slave Type is 99, slave Index is 0
SPI core clock speed value = 0xA801.
'1': IDCODE is '010219' (in hex).
'1': ID Check passed.
 '1': Erasing Device.
'1': Using Sector Erase.
'1': Erasing non-volatile quad-enable bit...
'1': Programming Flash.
'1': Reading device contents...
done.
'1': Verification completed.
'1':Programming in x4 mode.
S25FL256S Status Register Contents = 0x0200.
QUAD                                              :         1
BP2                                               :         0
BP1                                               :         0
BP0                                               :         0
Elapsed time =    957 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
amol.ghaware
If I tried with 1x mode then MCS file successfully programmed, but with 4x mode it is giving above error, DONE did not go high....
pulim
Hi @amol.ghaware
Did you generate the bitstream for spi bus width 4?
If not, can you try generating the bitstream for SPI bus width of 4.
You can select SPI bus width from bit stream properties.
amol.ghaware
Hi@pulim
I have to generate with spi bus width 4 only,
but with SPI bus width =4 only i got above error, and SPI bus width=1 MCS file successfully programmed
pratham
@amol.ghaware Can you attach part of schematic which would show fpga to spi flash interface connection?
-Pratham
amol.ghaware
Hi@
pratham
@amol.ghaware can you compare with this one here?
-Pratham
amol.ghaware
Hi@
Exactly same,same interface only using with same signals and pullup value also,can you tell me what may be the problem in 4x mode
amol.ghaware
Hi@pratham
Hi@ pulim
I am having this error still now,unable to solve,can anyone guide me
aher
Hi @amol.ghaware
Try setting SPI_32bit_addr yes along with spi_buswidth 4 option.
This is required for flashes of size 256Mb or above.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
kkn
amol.ghaware
why vivado lab programmer ?
kkn
you can use the vivado lab programmer instead of impact tool to program the S25FL256S flash for 7 series
amol.ghaware
I will try with Vivado lab programmer, but with same mcs for other board is programmed successfully with IMPACT only with same setting, IS this problem related to hardware ?
palmerhunt
Vivado lab programmer is worth trying
