MMCM dynamic phase shift: psdone never asserted
I have been trying to simulate dynamic phase shifting in a 7-series MMCM module.  I assert psen for one clock cycle, then wait for over twelve cycles of the psclk, but psdone always stays low.  Also if I look down inside the MMCME2_ADV primitive, none of the ps signals look to be toggling or doing anything when I send psen. I made this module with the clock wizard, but the MMCME2_ADV seems to be configured correctly when I look at the source.
*I reset the MMCM at the beginning of my simulation.
*I am not trying to shift the phase until thousands of ns after the MMCM has locked.
*I remembered to enable the dynamic phase shift feature, and to enable fine phase shift on my output clocks, when I was configuring the clock wizard.
*The psclk is running, and psen is synchronous to it.
*I have tried both incrementing and decrementing; results are the same.
*The Vivado version used is 2017.1; the clock wizard IP version is 5.4
Re: MMCM dynamic phase shift: psdone never asserted
Hi @jhane
Are you observing this behavior in simulation?
If yes, share the simulation snapshot here.
What is the frequency of PSCLK? Is PSCLK clean?
Vinay
Hi @vuppala
Here is a screenshot.  The top-level signals locked, psclk, psen, psincdec, and psdone are at the bottom.  Everything else is from inside the MMCM.
Yes psclk is clean.  It is running at 125 MHz.
It looks like this was never resolved.  Sadly I am seeing the same thing while simulating in Modelsim with models generated by Vivado 2019.1.
I had the same problem, using the MMCME2_ADV in VCS:  psdone never asserted.  I was using my firm's precompiled libraries.  (I instantiated the primitive myself; I didn't use the wizard.)  Then I tried recompiling the source (Vivado/data/verilog/src/unisims/MMCME2_ADV.v, version 2017.1, last revised 11/26/2014) into my work library and then it started working.  I don't understand why; I think the precompiled version I had been using was from the same source, but something must have been different.
Hi @kevinneilson @jhane @emcalnan @vuppala
#1  make sure that you select USE fine PS in the clocking wizard IP
#2 When using the direct primitive instantiation, Make sure that you set the below attribute.
