MMCM fine phase shift stopped working
I am having issues with the MMCM fine phase shifting. I had the phase shifting working, and at a certain point after rerunning the synthesis & implementation it stopped working while nothing has changed related to the Clock wizard IP's. I am using vivado 2018.2 and clock wizard v6.0 But I have had the same issue on version 2018.1 with IP version 5.7(i think).
Resetting the output products of the BD does not help, nor does rerunning the design runs.
What could cause this?
Re: MMCM fine phase shift stopped working
Hi @tlapauw,
You found the right information there. The Fine Phase Shift is not allowed / supported at any time, while also using the DRP function.
If you really need to use the DRP resources, you may have to use the Static Phase Shift instead, which is supported. Please not that the SPS has a coarser granularity, so you might not be able to achieve exactly the same phases you would with the DPS.
Andre Guerrero
Product Applications Engineer
Mentor
Mentor
when you say,  "stopped working",  are you referring to the behavior you observe in the silicon?     I recommend that you open the routed design in Vivado,  find the MMCM primitive, and then do a dump of all the properties on that MMCM.   Post them here, and the issue ought to be fairly clear.
With stopped working, I mean that the asserting PSEN for one PSCLK cycle does not result in a change of phase although the PSDONE gets asserted. I have observed this on my board (measured with an oscilloscope).
The strange thing is that it worked before, and that after changing something in another unrelated part of the design and generating the bitfile resulted in it not working anymore.
Are these the properties that you mentioned:
TOP_clk_wiz_0_3,
clk_wiz_v6_0_1_0_0,
{component_name=TOP_clk_wiz_0_3,
use_phase_alignment=true,
use_min_o_jitter=false,
use_max_i_jitter=false,
use_dyn_phase_shift=true,
use_inclk_switchover=false,
use_dyn_reconfig=true,
enable_axi=1,
feedback_source=FDBK_AUTO,
PRIMITIVE=MMCM,
num_out_clk=1,
clkin1_period=50.000,
clkin2_period=10.0,
use_power_down=false,
use_reset=true,
use_locked=true,
use_inclk_stopped=false,
feedback_type=SINGLE,
CLOCK_MGR_TYPE=NA,
manual_override=true}
Mentor
Mentor
No, these are the parameters on the clock wizard wrapper,  not the fundamental properties of the MMCM primitive cell in the design netlist.   Dig into the netlist when you open the design.   Hit control F to do a search for primitive cells with type MMCM, and you'll be able to find it pretty easily.
This should be it right (I am still somewhat trying to find my way in vivado). But thank you already for your time so far.
ADV_USEFUL_SKEW	false
ASYNC_REG	false
BANDWIDTH	OPTIMIZED
BEL	MMCME2_ADV.MMCME2_ADV
BLKNM
BLOCK_SYNTH.ADDER_THRESHOLD	16
BLOCK_SYNTH.AUTO_PIPELINING	-1
BLOCK_SYNTH.COMPARATOR_THRESHOLD	16
BLOCK_SYNTH.CONTROL_SET_THRESHOLD	2
BLOCK_SYNTH.EXTRACT_PARTITION	-1
BLOCK_SYNTH.FLATTEN_HIERARCHY
BLOCK_SYNTH.FLATTEN_INSIDE_PARTITION	-1
BLOCK_SYNTH.FSM_EXTRACTION
BLOCK_SYNTH.KEEP_EQUIVALENT_REGISTER	-1
BLOCK_SYNTH.LUT_COMBINING	-1
BLOCK_SYNTH.MAX_LUT_INPUT	6
BLOCK_SYNTH.MUXF_MAPPING	-1
BLOCK_SYNTH.PRESERVE_BOUNDARY	-1
BLOCK_SYNTH.RETIMING	-1
BLOCK_SYNTH.ROM_MAPPING	-1
BLOCK_SYNTH.SHREG_MIN_SIZE	3
BLOCK_SYNTH.STRATEGY	DEFAULT
BLOCK_SYNTH.USER_PROVIDED
BOX_TYPE	PRIMITIVE
BUFG	CLK
CAPACITANCE
CARRY_REMAP	1
CASCADE_HEIGHT	-1
CELL_BLOAT_FACTOR
CLASS	cell
CLKFBOUT_MULT_F	50.0
CLKFBOUT_PHASE	180.0
CLKFBOUT_USE_FINE_PS	true
CLKIN1_PERIOD	50.0
CLKIN2_PERIOD	0.0
CLKOUT0_DIVIDE_F	50.0
CLKOUT0_DUTY_CYCLE	0.5
CLKOUT0_PHASE	0.0
CLKOUT0_USE_FINE_PS	false
CLKOUT1_DIVIDE	1
CLKOUT1_DUTY_CYCLE	0.5
CLKOUT1_PHASE	0.0
CLKOUT1_USE_FINE_PS	false
CLKOUT2_DIVIDE	1
CLKOUT2_DUTY_CYCLE	0.5
CLKOUT2_PHASE	0.0
CLKOUT2_USE_FINE_PS	false
CLKOUT3_DIVIDE	1
CLKOUT3_DUTY_CYCLE	0.5
CLKOUT3_PHASE	0.0
CLKOUT3_USE_FINE_PS	false
CLKOUT4_CASCADE	false
CLKOUT4_DIVIDE	1
CLKOUT4_DUTY_CYCLE	0.5
CLKOUT4_PHASE	0.0
CLKOUT4_USE_FINE_PS	false
CLKOUT5_DIVIDE	1
CLKOUT5_DUTY_CYCLE	0.5
CLKOUT5_PHASE	0.0
CLKOUT5_USE_FINE_PS	false
CLKOUT6_DIVIDE	1
CLKOUT6_DUTY_CYCLE	0.5
CLKOUT6_PHASE	0.0
CLKOUT6_USE_FINE_PS	false
CLOCK_REGION
COMPENSATION	BUF_IN
CONTROL_SET_REMAP	NONE
CONVERT_BRAM8	false
CORE_GENERATION_INFO
C_AUX_RESET_HIGH
C_AUX_RST_WIDTH	0
C_DM_WIDTH	0
C_DQS_WIDTH	0
C_DQ_WIDTH	0
C_EMIO_GPIO_WIDTH	0
C_EN_EMIO_ENET0	0
C_EN_EMIO_ENET1	0
C_EN_EMIO_PJTAG	0
C_EN_EMIO_TRACE	0
C_EXT_RESET_HIGH
C_EXT_RST_WIDTH	0
C_FAMILY
C_FCLK_CLK0_BUF
C_FCLK_CLK1_BUF
C_FCLK_CLK2_BUF
C_FCLK_CLK3_BUF
C_GP0_EN_MODIFIABLE_TXN	0
C_GP1_EN_MODIFIABLE_TXN	0
C_INCLUDE_ACP_TRANS_CHECK	0
C_INCLUDE_TRACE_BUFFER	0
C_IRQ_F2P_MODE
C_MIO_PRIMITIVE	0
C_M_AXI_GP0_ENABLE_STATIC_REMAP	0
C_M_AXI_GP0_ID_WIDTH	0
C_M_AXI_GP0_THREAD_ID_WIDTH	0
C_M_AXI_GP1_ENABLE_STATIC_REMAP	0
C_M_AXI_GP1_ID_WIDTH	0
C_M_AXI_GP1_THREAD_ID_WIDTH	0
C_NUM_BUS_RST	0
C_NUM_F2P_INTR_INPUTS	0
C_NUM_INTERCONNECT_ARESETN	0
C_NUM_PERP_ARESETN	0
C_NUM_PERP_RST	0
C_PACKAGE_NAME
C_PS7_SI_REV
C_S_AXI_ACP_ARUSER_VAL	0
C_S_AXI_ACP_AWUSER_VAL	0
C_S_AXI_ACP_ID_WIDTH	0
C_S_AXI_ADDR_WIDTH	0
C_S_AXI_DATA_WIDTH	0
C_S_AXI_GP0_ID_WIDTH	0
C_S_AXI_GP1_ID_WIDTH	0
C_S_AXI_HP0_DATA_WIDTH	0
C_S_AXI_HP0_ID_WIDTH	0
C_S_AXI_HP1_DATA_WIDTH	0
C_S_AXI_HP1_ID_WIDTH	0
C_S_AXI_HP2_DATA_WIDTH	0
C_S_AXI_HP2_ID_WIDTH	0
C_S_AXI_HP3_DATA_WIDTH	0
C_S_AXI_HP3_ID_WIDTH	0
C_TRACE_BUFFER_CLOCK_DELAY	0
C_TRACE_BUFFER_FIFO_SIZE	0
C_TRACE_INTERNAL_WIDTH	0
C_TRACE_PIPELINE_WIDTH	0
C_USE_AXI_NONSECURE	0
C_USE_DEFAULT_ACP_USER_VAL	0
C_USE_M_AXI_GP0	0
C_USE_M_AXI_GP1	0
C_USE_S_AXI_ACP	0
C_USE_S_AXI_GP0	0
C_USE_S_AXI_GP1	0
C_USE_S_AXI_HP0	0
C_USE_S_AXI_HP1	0
C_USE_S_AXI_HP2	0
C_USE_S_AXI_HP3	0
DCI_VALUE	50
DELAY_BYPASS	false
DIVCLK_DIVIDE	1
DONT_PARTITION	false
DONT_TOUCH	false
DSP_FOLDING	false
DowngradeIPIdentifiedWarnings
EXTRACT_ENABLE	false
EXTRACT_RESET	false
FILE_NAME	d:/Pintail_WorkingDir/Ottawa/firmware/OttawaV1/OttawaV1.srcs/sources_1/bd/TOP/ip/TOP_clk_wiz_0_3/TOP_clk_wiz_0_3_clk_wiz.v
FSM_ENCODED_STATES
FSM_ENCODING	auto
FSM_SAFE_STATE	none
HBLKNM
HD.ISOLATED	false
HD.ISOLATED_EXEMPT	false
HD.PLATFORM	false
HD.PLATFORM_WRAPPER	false
HD.RECONFIGURABLE	false
HD.RECONFIGURABLE_CONTAINER	false
HD.RECONFIGURABLE_CONTAINER_PLACEMENT_RANGE
HD.RECONFIGURABLE_CONTAINER_ROUTING_RANGE
HD.RECONFIG_PLATFORM	false
HD.SHELL	false
HD.TANDEM	0
HLUTNM
HW_HANDOFF
H_SET
IBUF_DELAY_VALUE
IFD_DELAY_VALUE
INIT_VAL
IOB	AUTO
IOBDELAY	NONE
IOB_TRI_REG	false
IODELAY_GROUP
IPROGRAMMING
IS_BEL_FIXED	false
IS_BLACKBOX	false
IS_CE_INVERTED
IS_CLKINSEL_INVERTED	1'b0
IS_CLOCK_GATED	false
IS_DEBUGGABLE	true
IS_FANOUT_CONSTRAINED	0
IS_LOC_FIXED	false
IS_MATCHED	true
IS_ORIG_CELL	false
IS_PRIMITIVE	true
IS_PSEN_INVERTED	1'b0
IS_PSINCDEC_INVERTED	1'b0
IS_PWRDWN_INVERTED	1'b0
IS_REUSED	false
IS_RST_INVERTED	1'b0
IS_SEQUENTIAL	true
IS_S_INVERTED
KEEP	false
KEEP_HIERARCHY	TRUE
KEEP_PRSHELL_DISCONNECT	true
LINE_NUMBER	149
LOC	MMCME2_ADV_X0Y0
LOCK_PINS
LOPT_BUFG_MISC	false
LUTNM
LUT_REMAP	false
MACRO_NAME
MAX_FANOUT
MEM.ADDRESS_BEGIN	0
MEM.ADDRESS_END	0
MEM.ADDRESS_SPACE	true
MEM.ADDRESS_SPACE_BEGIN	0
MEM.ADDRESS_SPACE_DATA_LSB	0
MEM.ADDRESS_SPACE_DATA_MSB	0
MEM.ADDRESS_SPACE_DATA_WIDTH	0
MEM.ADDRESS_SPACE_END	0
MEM.ADDRESS_SPACE_WORD_WIDTH	0
MEM.CORE_MEMORY_WIDTH	0
MEM.DATA_LSB	0
MEM.DATA_MSB	0
MEM.ENDIANNESS	LITTLE
MEM.PORTA.ADDRESS_BEGIN	0
MEM.PORTA.ADDRESS_END	0
MEM.PORTA.DATA_BIT_LAYOUT
MEM.PORTA.DATA_LSB	0
MEM.PORTA.DATA_MSB	0
MEM.PORTB.ADDRESS_BEGIN	0
MEM.PORTB.ADDRESS_END	0
MEM.PORTB.DATA_BIT_LAYOUT
MEM.PORTB.DATA_LSB	0
MEM.PORTB.DATA_MSB	0
METHODOLOGY_DRC_VIOS
MUXF_REMAP	false
NAME	TOP_i/Timing/clk_wiz_0/inst/CLK_CORE_DRP_I/clk_inst/mmcm_adv_inst
NODELAY	false
OPROGRAMMING
ORIG_CELL_NAME
ORIG_REF_NAME
PARENT	TOP_i/Timing/clk_wiz_0/inst/CLK_CORE_DRP_I/clk_inst
PBLOCK
PHASESHIFT_MODE	WAVEFORM
POWER_OPTED_CE
PRIMITIVE_COUNT	1
PRIMITIVE_GROUP	CLK
PRIMITIVE_LEVEL	LEAF
PRIMITIVE_SUBGROUP	gclk
PRIMITIVE_TYPE	CLK.gclk.MMCME2_ADV
PRSHELL_OK_FOR_IMPL	false
PRSHELL_SKIP_IP	false
PWR_MODE	STD
RAM_DECOMP	power
RAM_STYLE	distributed
REF_JITTER1	0.01
REF_JITTER2	0.01
REF_NAME	MMCME2_ADV
REG_TO_SRL	false
RETIMING_BACKWARD	-1
RETIMING_FORWARD	-1
REUSE_STATUS
RLOC
ROM_STYLE	distributed
RPM
RPM_GRID	GRID
RW_ADDR_COLLISION	true
SDX_FEATURE_ROM	false
SETUP_SLACK	0.0
SEU_PROTECTED	0
SHREG_EXTRACT	YES
SIM_COLLISION_CHECK	WARNING_ONLY
SLR
SLR_INDEX	0
SOFT_HLUTNM
SRL_STYLE	srl_reg
SRL_TO_REG	false
SS_EN	FALSE
SS_MODE	CENTER_HIGH
SS_MOD_PERIOD	10000
STARTUP_WAIT	false
STATUS	PLACED
TRANSIENT_FILTER	BYPASS
USER_LAGUNA	false
USER_SLL_REG	false
USER_SLR_ASSIGNMENT
USE_DSP	NO
USE_DSP48	NO
USE_LUTNM	true
USE_RLOC	true
USE_TRACE_DATA_EDGE_DETECTOR	0
XBLKNM
XILINX_LEGACY_PRIM
XPM_CDC	NONE
XSTLIB	false
X_CORE_INFO
srl_bus_name
srl_name
It seems to be an issue with combining Dynamic reconfiguration with the dynamic fine phase shift. When the AXI - reconfiguration is disabled, the phase shift works again.
I have found the following in XAPP888, but I think the meaning is somewhat unclear
Frequency, phase, and duty cycle can all be changed through the DRP port.
Fine-phase shifting is not allowed for the initial configuration or during reconfiguration.
My interpretation would be that the fine phase shifting is not allowed to be enabled in the initial configuration, but can later be enabled trough the DRP port, furthermore do not do any phase shifting during reconfiguration.
Then on the other hand nowhere in any application note or manual can I find the register which can be used to enable the fine phase shifting.
Hi @tlapauw,
Andre Guerrero
