Making differential clock signal.
Hi. I', using xcku025-ffva-1156 (ultrascale + FPGA)
I am referring to application notes provided by xilinx.
I am going to use the reference code provided in xapp1315.
In this reference code, an external clock of 100 MHz enters to FPGA, passes IBUFDS_DIFF_OUT, and then goes to idelaye3.
I am going to design my top file containing this logic as shown in the picture below
The reference code  should receive 100 MHZ external clocks (go to IBUFDS), but my top design has only 50 MHZ external clocks.
What's the best way to solve a case like this?
The way I thought about it was to insert mmcm,  I'm not sure if the IDELAYE3 works differently, but the results didn't come out well.
Re: Making differential clock signal.
Hi @kangsungsik
This is already answered on your similar post
https://forums.xilinx.com/t5/Versal-and-UltraScale/IDATAIN-vs-DATAIN-in-IDELAYE3-input-port-xapp1315/m-p/1075724#M13277
Hi @kangsungsik
Why do you want a differential clock inside the FPGA ?
Hi. @drjohnsmith
The reason is because I want to use xapp1315 as a sub module in my design.
And it is because in xapp1315, the external clock passes IBUFDS_DIFF_OUT and both positive and negative are used.
