pcaddick
MicroBlaze memory issues on Virtex7
I have created a very simple microblaze design. The only thing it has attached to it is a UART and a DDR3 MIG. I have exported this to the SDK and implemented the memory test template. So this design is about as simple as you can get. When I do so I get the error
microblaze_0_local_memory_ilmb_bram_if_cntlr_microblaze_0_local_memory_dlmb_bram_if_cntlr' overflowed by 1392 bytes
I have tried increasing the micro-blaze memory to a max and I've tried commenting out the software code. The error only goes away when I reduce the software program down to something completely useless (pretty much everything commented out). I can't believe that this the best I can do with the microblaze. I'm used to using the Zynq device where I've had no such problems.  Please advise as to how I can resolve this issue and please don't say "go back to the Zynq".
pcaddick
fixed this myself. For some surprising reason the address map doesn't reflect the new larger memory. This I had to manually change. When I did so I no longer got the error. Odd this I would have expected to have been updated automatically.
pcaddick
