soumya_10
Microblaze in virtex 5
when we run the post synthesis once the microblaze is created i get an error stating that
D:/xyzabc/microblaze/microblaze/hdl/dlmb_cntlr_wrapper.vhd ,Line 227. Size mismatch. String literal "00000000010000000000000000000000" is of size 32 but is expected to be of size 0.
and when i click on the error then it opens up this .vhd file,dlmb_cntlr_wrapper.vhd and the cursor points out to this line
in lmb_bram_if_cntlr
C_MASK => X"00400000",
i am unable to figure out what exactly is the problem in it and i also want to know the solution to it
thanks
jcabel
You probably have something misconfigured around the LMB.
That's all I can apport with the little and vague details you provide.
I wish all my problems' solution was "I do this and I see that, what do I do next?"
soumya_10
dlmb_cntlr : lmb_bram_if_cntlr
generic map (
C_BASEADDR => X"00000000",
C_HIGHADDR => X"00007fff",
C_FAMILY => "virtex5",
C_LMB_AWIDTH => 32,
C_LMB_DWIDTH => 32,
C_ECC => 0,
C_INTERCONNECT => 0,
C_FAULT_INJECT => 0,
C_CE_FAILING_REGISTERS => 0,
C_UE_FAILING_REGISTERS => 0,
C_ECC_STATUS_REGISTERS => 0,
C_ECC_ONOFF_REGISTER => 0,
C_ECC_ONOFF_RESET_VALUE => 1,
C_CE_COUNTER_WIDTH => 0,
C_WRITE_ACCESS => 2,
C_SPLB_CTRL_BASEADDR => X"FFFFFFFF",
C_SPLB_CTRL_HIGHADDR => X"00000000",
C_SPLB_CTRL_AWIDTH => 32,
C_SPLB_CTRL_DWIDTH => 32,
C_SPLB_CTRL_P2P => 0,
C_SPLB_CTRL_MID_WIDTH => 1,
C_SPLB_CTRL_NUM_MASTERS => 1,
C_SPLB_CTRL_SUPPORT_BURSTS => 0,
C_SPLB_CTRL_NATIVE_DWIDTH => 32,
C_S_AXI_CTRL_BASEADDR => X"FFFFFFFF",
C_S_AXI_CTRL_HIGHADDR => X"00000000",
C_S_AXI_CTRL_ADDR_WIDTH => 32,
C_S_AXI_CTRL_DATA_WIDTH => 32
ERROR:HDLParsers:3384 - "D:/ANAVARAN/microblaze/micro_blaze/hdl/dlmb_cntlr_wrapper.vhd" Line 227. Size mismatch. String literal "00000000010000000000000000000000" is of size 32 but is expected to be of size 0.
ERROR:EDK:546 - Aborting XST flow execution!
ERROR:EDK:440 - platgen failed with errors!
ERROR:EDK -
Error while running "make -f micro_blaze.make netlist".
ERROR: synthesizing XPS module failed!
soumya_10
Line 227. Size mismatch. String literal "00000000010000000000000000000000" is of size 32 but is expected to be of size 0. corresponds to this
jcabel
It would help more the block diagram
