041064974
Multi-Gigabit-Transceiver (MGT) operating distance
we want to build a modular system where Xilinx FPGAs (7-series) shall interconnect via their MGTs.
Due to the modular apporach, there will be up to 4 connectors, up to 25cm (10 inch) PCB and up to 15 cm (0.6 inch) Twinax-Cable between the FPGAs.
Connectors, PCB-Traces and Cables are all designed for 100 Ohm differential impedance and high speed (>10Gbit/s) data transmission.
Do you think this will work with up to 12.5GBit/s?
In addition, we want to connect 7-series FPGAs to SFP+ modules using the same connection (up to 4 connectors, up to 25cm (10 inch) PCB and up to 15 cm (0.6 inch) Twinax-Cable).
Niels
austin
04...
Don't think:  simulate!
It is not a guess.  It is not an art.  You put the Xilinx provided models, with your actual PCB layout, connector models from their manufacturers, along with the cable models from their manufacturer, specify a pattern, and you see an eye pattern.
OPEN = error free, OK.
CLOSED = errors, bad, will not work.
Contact you local field application engineer/MGT specialist for help.  Xilinx and our distributor(s) know exactly what you need to do to be successful.
Austin Lesea
Principal Engineer
Xilinx San Jose
041064974
Austin,
thanks for your reply.
I hoped that there are some rules of thumb how many inches of copper and connectos the Xilinx MGTs can deal with.
So I will contact my local FAE and discuss the smiulation topic. Hopefully,  PCB, connector, cable and SFP vendor can provide modles to me.
Niels
