05-02-2016 03:46 AM
I'm having a problem which I can't solve for days now, although it doesn't seem to be such a tricky one. So I decided to ask here for some input. I'm using the ISE Design Suite 14.7.
I'm basically trying to switch on and off multiple clocks and output them from my design for a Kintex-7 XC7K325T.
The first step is a PLL. From the board clock it generates the clock which will be gated as well as a second clock which will be output directly.
The second step consists of multiple (six) BUFGCE elements which should do the clock gating. They all have the same input clock (from the aforementioned PLL), but individual enable signals.
Additionally there is a second PLL stage with the same input clock as the BUFGCEs (this PLL will be dynamically reconfigurable, that's why I need the second PLL). Finally its output again is clock gated by a BUFGCE and another enable signal.
I simplified my design to the following code:
---------------------------------------------------------------------------------- -- LIBRARIES -- ---------------------------------------------------------------------------------- library ieee; library UNISIM; use ieee.std_logic_1164.all; use UNISIM.vcomponents.all; ---------------------------------------------------------------------------------- -- ARCHITECTURE -- ---------------------------------------------------------------------------------- architecture beh of top is signal global_board_clk : std_logic; signal signal_reset : std_logic; signal signal_PISO_PLL_locked : std_logic; signal signal_controller_clk : std_logic; signal signal_asic_clk : std_logic; signal signal_locked : std_logic; component PISO_clk port ( -- Clock in ports CLK_IN1_P : in std_logic; CLK_IN1_N : in std_logic; -- Clock out ports CLK_OUT1 : out std_logic; cntrl_clk : out std_logic; -- Status and control signals RESET : in std_logic; LOCKED : out std_logic ); end component; component dummy_measurement_PLL port ( CLK_IN1 : in std_logic; CLK_OUT1 : out std_logic; RESET : in std_logic; LOCKED : out std_logic ); end component; begin signal_reset <= not reset; -- needs to be like this because of the reset button hardware -- the PLL generates one direct output clock (CLK_OUT1) and one clock which will be gated (cntrl_clk) PISO_clk_PLL : PISO_clk port map ( CLK_IN1_P => clk_p, CLK_IN1_N => clk_n, CLK_OUT1 => delayed_PLL, cntrl_clk => signal_controller_clk, RESET => reset, LOCKED => signal_PISO_PLL_locked ); BUFG_sys_clock : BUFG port map ( O => global_board_clk, I => signal_controller_clk ); -- Clock gating buffers... -- inst25 BUFGCE_inst25 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO25_clk_enable, -- PISO110 clock enable O => asic_piso_clk25 -- PISO110 clock output ); -- inst30 BUFGCE_inst30 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO30_clk_enable, -- PISO110 clock enable O => asic_piso_clk30 -- PISO110 clock output ); -- inst55 BUFGCE_inst55 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO55_clk_enable, -- PISO110 clock enable O => asic_piso_clk55 -- PISO110 clock output ); -- inst75 BUFGCE_inst75 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO75_clk_enable, -- PISO110 clock enable O => asic_piso_clk75 -- PISO110 clock output ); -- inst84 BUFGCE_inst84 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO84_clk_enable, -- PISO84 clock enable O => asic_piso_clk84 -- PISO84 clock output ); -- inst110 BUFGCE_inst110 : BUFGCE port map ( I => global_board_clk, -- common PISO clock CE => PISO110_clk_enable, -- PISO110 clock enable O => asic_piso_clk110 -- PISO110 clock output ); m_dummy_PLL : dummy_measurement_PLL port map ( CLK_IN1 => global_board_clk, CLK_OUT1 => signal_asic_clk, RESET => signal_reset, LOCKED => signal_locked ); -- buffer for measurement clock: BUFGCE_inst : BUFGCE port map ( I => signal_asic_clk, -- traget circuit base clock CE => Tar_clk_enable, -- target circuit enable O => asic_Tar_clk -- final target circuit clock signal ); end architecture beh;
Sythesis is fine, but at the implementation I get the following errors:
"ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The load BUFGCTRL component <BUFGCE_inst25> is placed at site <BUFGCTRL_X0Y29>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The load BUFGCTRL component <BUFGCE_inst55> is placed at site <BUFGCTRL_X0Y21>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The load BUFGCTRL component <BUFGCE_inst75> is placed at site <BUFGCTRL_X0Y26>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The load BUFGCTRL component <BUFGCE_inst84> is placed at site <BUFGCTRL_X0Y9>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The load BUFGCTRL component <BUFGCE_inst110> is placed at site <BUFGCTRL_X0Y30>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y7>. The load BUFGCTRL component <BUFG_sys_clock> is placed at site <BUFGCTRL_X0Y18>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Pack:1654 - The timing-driven placement phase encountered an error."
I expected BUFG output signals to be available globally and hence in all sites.
The link http://www.xilinx.com/support/answers/43637.html
suggests to constrain the location of the BUFGCTRLs to force them to adjacent sites.
So I tried this. It seems to work fine to constrain the "BUFG_sys_clock" and one of the "BUFGCE_inst" objects.
But any attempts of constraining more objects failed. (Pack:2811 Errors and again Place:1131)
(What makes somehow sense, I guess I cannot have seven adjacent sites.)
"The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM)."
Does that mean I can only drive the two BUFGCEs of the neighbouring sites of the PLL? Not more?
Is there a way to gate a clock with more enable signals? (I could of course build some clock gating in a logic block, but I can't imagine that's the best solution.)
Is there a general problem with my strategy of solving the task or do I just try to constrain the locations in a wrong way?
I also found the hint to set an environment variable to demote the error to a warning. If I do this, the implement step works fine. However I'd rather like to understand and solve the actual problem than ignore it.
(http://www.xilinx.com/support/answers/34346.html)
I'd appreciate your help,
asteric.
05-05-2016 10:16 PM
Hi @asteric_
Are you using clocking wizard IP?
If yes, then disable buffer insertion on PLL/MMCM outputs as you already have buffers instantiated in code.
05-02-2016 04:45 AM - edited 05-02-2016 04:49 AM
Hi @asteric_
Can you try removing this BUFG_sys_clock?
Why are you cascading PLL's?
05-03-2016 02:40 PM
Thanks a lot for your reply.
I need the cascaded PLLs, because the second one is a reconfigurable PLL. This isn't obvious in the example code, because I wanted to keep it simple.
I tried to remove the buffer, but the errors stay. Only the PISO_clk_PLL/clkout2_buf is now mentioned instead of the BUFG_sys_clock of course.
Best regards.
05-03-2016 09:25 PM
Hi @asteric_
Please post the new error messages.
05-05-2016 01:18 AM
Sure.
I just changed
to
cntrl_clk => global_board_clk,
and removed the BUFG_sys_clock.
The error messages are now as follows:
ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y8>. The load BUFGCTRL component <m_dummy_PLL/clkin1_buf> is placed at site <BUFGCTRL_X0Y23>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y8>. The load BUFGCTRL component <BUFGCE_inst30> is placed at site <BUFGCTRL_X0Y12>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y8>. The load BUFGCTRL component <BUFGCE_inst55> is placed at site <BUFGCTRL_X0Y20>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y8>. The load BUFGCTRL component <BUFGCE_inst75> is placed at site <BUFGCTRL_X0Y26>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Place:1131 - Unroutable Placement! A cascaded BUFGCTRL clock component pair have been found that are not placed at a routable site pair. The driver BUFGCTRL component <PISO_clk_PLL/clkout2_buf> is placed at site <BUFGCTRL_X0Y8>. The load BUFGCTRL component <BUFGCE_inst84> is placed at site <BUFGCTRL_X0Y2>. The BUFGCTRL components can use the fast path between them if they are placed in adjacent BUFGCTRL sites, and both are in the same half of the device (TOP or BOTTOM). You may want to analyze why this problem exists and correct it. This placement is UNROUTABLE in PAR and therefore, this error condition should be fixed in your design. You may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this message to a WARNING in order to generate an NCD file. This NCD file can then be used in FPGA Editor to debug the problem. A list of all the COMP.PINS used in this clock placement rule is listed below. These examples can be used directly in the .ucf file to demote this ERROR to a WARNING. ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Thank you for your help.
05-05-2016 10:16 PM
Hi @asteric_
05-11-2016 09:45 AM
Hi Deepika.
I changed the buffer as in the screenshot and the error disappeared. Although I'm not sure why the buffer was a problem. Could you maybe explain what happened, so I don't fall over this buffer-mix-up again?
Anyway thank you a lot for your help! :-)
asteric
05-11-2016 10:29 PM - edited 05-11-2016 10:30 PM
Hi @asteric_
Glad to know that it helped.
You had an additional BUFG on the MMCM output path which is not needed as you are anyways driving this output to BUFGCE. This additional BUFG was causing the cascading problem.
