tonic456
Noise issue on LVDS port.(Kintex7 160T)
I developed an LVDS input board using xc7k160t-2ffg676 device.
However, there is often a defect in the bank to which the LVDS is connected. (2.5V Bank12, 13, 14)
Data is noisy or data is not received at all.
LVDS is output from the THC63LVD device. And TVS diode is connected to LVDS output terminal.
When I checked the data with the oscilloscope, I found that there was no problem with the voltage value.
In what case does this issue occur?
sandrao
Community Manager
Community Manager
Hi @tonic456
How is the input LVDS constrained? How much timing margin are you seeing on the path?
Have you done an IBIS simulation of the path? Can you share what the simulation of the path looks like?
Can you also share the scope shot of what the input to the FPGA looks like?
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
tonic456
Hi, Sandy
The problem I have seems to be a physical problem.
Only 20% of the boards produced were defective.
When FPGA is replaced with a new product, the LVDS data is normal.
Is there an example of a protection schematic for the LVDS input?
