namrata_kogalur
Not able to run program for Basys3
I generated bitfile for my board, Basys 3 and ran the program. But it would not go beyond 1% . So, I had to force stop the program and start again but I am not able to reset my fpga board. When I press the FPGA configuration reset button, an orange led light,LD16 turns on indicating busy. Even the display is not working. I am not able to run any programs. How do I solve this?
Thank you
kkn
could you provide the log file during programming and the error snapshot to debug.
You can attach it to this thread
bluecom
Dear, I am a new FPGA learner from Basys3 , and step step in manual "Getting Started",I hope see the LED in working,but NO! How can I do next?
gnarahar
@bluecom It will be more helpful if you can mention what steps you did and which guide you followed and where you are stuck.
https://reference.digilentinc.com/learn/programmable-logic/tutorials/basys-3-getting-started/start
Were you able to perform all the steps in above link?
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
bluecom
Thanks,after I do it I will ask more, for I am a new FPGA learner.
bluecom
Dear ,I want to display as  "1","2","3","4" on seven-segments,  but I can not ,could you give me a DEMO source code?
and let me know how to do in step by step,and to the end perfectly.
bluecom
there have some errors,how can I do next
launch_xsim -simset sim_1 -mode behavioral
[Runs 36-25] xelab application returned error(s). Please see 'F:/baojf/project_20160901/project_20160901.sim/sim_1/behav/xelab.log' file for more details.
[Common 17-69] Command failed: Failed to compile the design!
