ODELAY2 tap value not changing (VAR_LOAD)
I am running on a Kintex7. I have (I admit) an unusual application of an ODELAY2 primitive I am currently testing. Behavioural simulation suggests the design should work but in practise it doesn't. I have monitored as many of the signals I can in hardware manager and they all seems to be correct, apart from the cntvalueout (current tap value) is fixed at zero.
Here is my design:
I am trying to continuously vary the delay on a clock output (to a device pin) pseudorandomly.  I created a 5 bit pseudorandom generator to connect to the cntvaluein port of the ODELAY2.
My ODELAY2 parameters are:
generics
CINVCTRL = false
DELAYsrc=CLKIN
HIGH_PERFORMANCE_MODe = false
ODELAY_TYPE = VAR_LOAD
ODELAY_VALUE = 0
PIPE_SEL = FALSE
REFCLK_FREQUENCY = 200.0
SIGNAL_PATTERN = CLOCK
ports
cntvalueout  = tap value monitored directly by ILA core, clocked by same undelayed clock source as c, clkin below
dataout = delayed output clock, drives OBUFT
c = my undelayed clock source (70MHz ish)
cinvctrl = '0'
clkin = my undelayed clock source
cntvaluein = my 5 bit PRBS sequence
inc = '0'
LD = '1' (permanently...)
LDPIPEEN = '1'
ODATAIN = '0'
REGRST = connected to a reset that goes low a handful of cycles after configuration
So, in my ILA I can see:
- the cntvaluein changing correctly
- REGRST is zero
- the ILA core is running so the C, CLKIN inputs must be running
- my cntvalueout is permanently zero
Looking at the documentation I can see no port dependencies no restrictions I am violating.
Am I okay to assert LD before REGRST is released? Any ideas as to what I have done wrong?
I can see fror the implemented design that the IDELAYCTRL is instantiated, in the same regionas the ODELAY2, and has a valid refclk input.
Re: ODELAY2 tap value not changing (VAR_LOAD)
As I understand the docu, in VAR_LOAD mode the REGRST should be affecting anything. The REGRST affects the pipeline register.
But from spec- When LD is pulsed the value present at CNTVALUEIN<4:0> will be the new tap value.
So I think you can try out and change LD so that it is pulsed (high when a new pseudo-random value needs to be loaded). Then observe CNTVALUEOUT.
It is also necessary to inst the IDELAYCTRL primitive.
FPGA enthusiast!
All PMs will be ignored
That was my main concern. I will try and pulse LD every other clock cycle then. This isn't ideal, I had hoped to change it every clock cycle, but this may be okay.
I will report back.
Well pulsing the LD every other clock cycle did nothing to change it. The cntvalueout is still stuck at zero...
Well can't help you more on that. Maybe some Xilinx support personnel can.
But I can't agree more with your statement, "Behavioural simulation suggests the design should work but in practise it doesn't. "
I am currently struggling with a design having IDDR and the simulation results are completely different than what I observe on actual h/w with ILA cores inserted!
FPGA enthusiast!
that's okay, thanks for helping
I still cannot get my ODELAYs working and am running out of ideas.
I have reduced the complexity of my design as much as I can and added a VIO so that I can change certain parameters on the fly in hardware to see if I am doing something wrong.
I actually am trying to program 4 ODELAYS in the same bank. For sanity, I connected 1 as FIXED, with a delay tap of 5. My ILA monitor correctly shows CNTVALUEOUT for this ODELAY to be 5. Plus, I can see an output waveform on an oscilloscope when I measure on the board, so I know that the ODELAY there is working. The others have nothing on them.
The other 3 ODELAYs I cannot get to change from a tap value of 0. I have tried:
- Pulsing LD for 2 cycles, instead of 1
- Setting "PIPE_SEL" to False, incorrectly set this to True, even though I'm in VAR_LOAD mode
- Pulsing CE, instead of keeping it low, as the datasheet suggests. I'm not using INC/DEC
- Tying LDPIPEEN low, I has this tied high before.
- Keeping REGSRT low, as I'm not using pipeline mode. Before it was connected to my reset
As I say, I am trying to delay a clock signal, and this same (undelayed) clock signal clocks in the CNTVALUEIN with LD. This clock is running at 70MHz.
What am I doing wrong? Why are my VAR_LOAD ODELAYs stuck as zero and not outputting anything at all?
Okay, I maanged to get the CNTVALUEOUT to change, but I don't know why I needed to do the change I did.
I tried changing the delay input attribute from CLKIN to ODATAIN and the SIGNAL_PATTERN attribute from CLOCK to DATA. I tied the CLKIN input to '0' and the ODATAIN input to '1'. That is all I changed. Now I can see the CNTVALUEOUT changing as expected.
Can you not used VAR_LOAD with a CLKIN signal?
Come on guys, what's going on? I can find nothing in the documentation that says this behaviour is expected. I am re-reading as much as I can for anything I've missed and I can't see anything. Can someone explain?
